First, I'm not a GE tech * STOP! * Door opened should turn off all power except the display. This is a safety measure, * Unplug and DO NOT use! * Check warranty. Call for service. * Check with store or vendor for replacement. Aloha, ukeboy57
I would be very careful when working on the microwave oven casing as these are insulated to reduce radiation leakage during operation. It is hard to know how the door handle fits your oven as there is no make and model number provided. Usually these are press oven type levers that are interlocked into a latch that is closed during operation to avoid accidental opening of the door. If you provide more details in the comment field someone on Fixya may be able to give you a solution for your door handle.
The electronics have lost their marbles. When a nuker door is opened the safety switch connected to the door is designed to turn the unit off and not on. You just better work fast when you put stuff in or take it out!!!!!!!
It is likely a bad door switch or mount. See the help file here.
On some models, the door switches, fuses, and TCOs / thermal cutouts / thermostats must be checked, too. See photo below.
There
should be a "mini-manual" (tech sheet) hidden inside the unit
- behind the
back, behind the control panel, or hidden on the left side behind the grille - which is
very helpful when troubleshooting, testing, and locating
components.
You can find
helpful exploded view diagrams and order parts by entering your full
model number from the tag on the oven here.
We'rehappy
to help you with free advice and we'd appreciate your thoughtful rating
of our answer.
Bad switch alignment. Some models can have an adjustment. Look carefully at the latch for any sign of damage. There are three switdhes that must simultaneously be activated, or the oven won't work. If, during the operation of the oven, the door is opened and the switches DONT simultaneously trigger, the monitor switch will detect this condition and short the incoming power directly to ground, which will blow the internal fuse, and possibly also trip the circuit breaker.
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open.
However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp. Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
If the light is not operating properly, you will want to have it checked by an authorized service technician. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.Advantium - Interior Light Operation While Microwaving
Check here
you messed up the safety interlok switch on the door by adjusting it, that is to blow the internal fuse in the event the door is opened during operation,you need to re-adjust the door safety interlok switch,then replace the fuse and you should be back on track and running
If the light comes on during cooking then the bulb is ok.. in all probability the problem is the door switch that senses when teh door is open and activates the light... Hope that helps..
