Question about Jensen Nvx200 3.5 Touch & Go Screen Portable Car Gps Navigation System B
How do I update the system
The system has never been updated and I want to make sure it has the newest information
Does anybody support xp
XP has been Sunset-ed. Meaning no more Microsoft support.
You can still use it, but at a risk, because there will be NO more security patches, once somebody figures out a way to get past the most latest patch, then if your computer is ever hacked, then you will be vulnerable.
I still use XP, it was a good OS! I am just very careful what I do with that computer.
Slowly, as the software keeps getting updated, XP will be so outdated, that those pieces of software I use will also, no longer update?
Does anybody support it? Well Microsoft doesn't, and they made it. You probably can still get service, but I am sure they will want to sell you on an upgrade to newest OS.
Apr 10, 2015 | Microsoft Windows XP Professional
Serial Number (system): W8844DCR1AX serial numbers check
Safari will update to the newest version you Mac OS supports through the software update feature. If it is still out of date then you need to update your Mac OS version through the App store.
Sep 07, 2014 | Computers & Internet
I have windows vista 32bit OS. After doing windows updates. My computer doesnt work anymore. Is there A way to reset my computer back SINCE I can no longer boot up in safe mode or regulare mode.
Tough problem. You need to get that disk into another computer first then:
From your working Windows installation navigate to the Windows\System32\config folder on his drive and rename or *move* the following files out of the System32\config folder:
DEFAULT SECURITY SOFTWARE SYSTEM SAM
The files can be renamed with a .old extension or to eliminate clutter they can (should) be moved to another temp location.
Now, navigate to the System Volume Information folder on his drive, inside which you will fing a _restore{... folder which contains Restore Point folders numbered as such: RP1, RP2, RP3... Select the newest RP folder and inside that folder you will find a "Snapshot" folder the containing a backup of the registry hives. Copy the following files from the snapshot folder to the System32\config folder, making sure to rename them to the same names as the files they will be replacing:
Rename _REGISTRY_USER_.DEFAULT to DEFAULT • Rename _REGISTRY_MACHINE_SECURITY to SECURITY • Rename _REGISTRY_MACHINE_SOFTWARE to SOFTWARE • Rename _REGISTRY_MACHINE_SYSTEM to SYSTEM • Rename _REGISTRY_MACHINE_SAM to SAM
That may permit you to boot the computer, if it does boot to finish the repair do a System Restore to the newest available point.
Good Luck!!
Hope this information will help.
Your response is very much appreciated. Thank you for using Fixya...
Sep 28, 2011 | Gateway Computers & Internet
I just bought a new r4 and after almost a month of goood use i updated my system to the newest system than one day an error occured whiule opening my r4 games and found it saying An error has occured....
Hey Farooga,
The newest Nintendo update (1.4.1 or 1.4.2) blocks most flash cards on the DSi and DSi XL consoles so it's quite likely you've fallen victim to this. Check out DSCardWorld.com's blog post about it here:
http://www.dscardworld.com/blog/2010/09/24/dsi-1-4-1-firmware-fixes-for-acekard-2i-ezflash-vi-m3i-zero/
You can probably buy a card that works with the 1.4.1 update like the Acekard 2i, EZFlash Vi or M3i Zero. However, make sure you only buy the real one as fake/clone cards can't be updated when Nintendo releases a new firmware (it makes them cheaper to produce that way, which is why they don't do it). I recommend grabbing them from DSCardWorld.com itself or nds-gear.com if you're in Canada or Europe, since their international shipping rates are a bit cheaper.
Sep 19, 2010 | Nintendo DS Console
I have a compaq presario Model # CQ61-319Wm when
This problem is usually resolved by updating your BIOS. Go to the start button > programs > Accessories > System information. When that window comes up, scroll down and write down the BIOS version and the date it was installed or issues. Now go to the link below and put in the model number of the laptop, don't worry that it is HP's site, they own Compaq. The next window will give you choices, choose software and drivers. Now choose your operating system from the drop down menu. Look below for your choices of drivers. There will be choices for BIOS updates. I am assuming you have Windows 7 on that system. Make sure that you know if you have a 32 bit or 64 bit version. You can find that out by going to the control panel > system > look at the window and will tell you what version you have. Once you know that, then you can choose the correct driver selection....there are a couple of choices, just choose the newest BIOS update, it is dated 2010. Download the file to your desktop or a folder of your choice, once it is downloaded, close all open programs, make sure the battery if fully charged and you have the laptop plugged into the AC outlet. Now run the program and follow the prompts, that should fix your problem. Good luck
Jun 21, 2010 | HP Pavilion dv4000 Notebook
NB500MG1F firmware updates, where do I find them?
For the NB500MG1F you can find the newest version firmware update download here: http://www.funaiservice.com/information/firmware.cfm
I already installed and it is working great now
May 01, 2010 | Magnavox NB500MGX BluRay Player
I have downloaded and installed Java (alot) and still can't use pogo, get the same message, Need to install java.
under internet explore click on TOOLS -->INTERNET OPTIONS --> advanced tab ---> find "Java (Sun) --> make sure the box beside it is clicked to make sure java ins enabled.
I also recommend upgrading to the newest version of IE.
http://www.ieaddons.com/en/
are u getting ur java program from
http://www.java.com/en/download/index.jsp
update that one more time after u have updated your IE.
Oct 16, 2009 | Microsoft Windows XP Professional
Music lag on all players
have you tried updating your sound drivers?
goto system properties and make sure you have the newest sound driver installed.
Aug 15, 2009 | Computers & Internet
Internet explorer suddenly stops working
Could be several things, sometimes the application needs updating (do you have the newest IE application)? and if so try to run disk clean up/disk defragmenter every so often to optomize your pc. (start tab, accessories tab, system tools and select defrag or cleanup option) Also worse case scenario you could have a virus or malicious software. Try running your virus scan if you have one if not I would suggest getting Mcaffe. If that doesn't work you may have to get it reformatted at a computer shop and reload your operating system
Aug 06, 2009 | HP Pavilion dv6000z Notebook
Update to version 4.05
Just follow the instruction on this website and it will help you to download and install the newest and latest updates fo the psp. On number 3 un the download information there is another link that lets you download the file so make sure that you do not look over the "DOWNLOAD NOW" button.
http://www.us.playstation.com/Support/SystemUpdates/PSP/PC.html
Mar 20, 2009 | Sony PlayStation Portable (PSP) Console
Jensen Nvx200 3.5 Touch & Go Screen Portable Car Gps Navigation System B Logo
26 people viewed this question
Top Jensen GPS Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a Jensen GPS Expert? Answer questions, earn points and help others
