My dell inspiron 1420 can not burn nor read an empty cd even after formating the operating system
Stephen buddy, we need to talk. I do NOT understand anything you are trying to describe. Okay, so you installed a FRESH Operating System and now it is NOT recognizing your DVD-rom, right? Okay, restart the computer and let Windows load up fully. Check Control Panel and check your list of Devices. Sometimes, when you re-install and O.S., you may have to update the firmware or drivers for certain devices.
SOURCE: Dell Latitude Dell DVD player
Hi
We will first start with these steps and let me if is still resolved or not.
1. http://support.microsoft.com/default.aspx/kb/929461
Do this step and restart your laptop. Let me know what kind of dvds are you using. Are they movies or with data.
2. Run a 32 bit dell diags on the drive. You can access Dell diagnostics by pressing F12 when you seeing the Dell logo when you start the system. You may have to try couple of times to get to the screen. It will show you one time boot menu. Select diagnostics. Alternatively, if you have Dell diagnostics or drivers cd, insert that and in the one time boot menu select cd dvd and press enter.
It will take you to the diagnostics menu. Select Test my system, then custom diags and then ran a diags on the drive. If they test fails it might be time to replace the drive. If you are in warranty talk to dell tech support and tell them that 32 bit diags on drive failed they will just replace the drive, if not in warranty let me know I will help you in ordering the spare parts online. Drive is not that costly.
3. IF the diags have passed and still having the issue boot system to safe mode and then go to My computer, right click the drive and click on explore. Check if you can see any contents of your dvd. If you can then the culprit is the OS or windows xp then we can do more steps. To access safe mode press F8 when u see the dell logo during start up.
Do share you experience so that I can know how it is working
Thank you
Rakesh
Expert in Dell Laptops.
SOURCE: dell dvd drive not reading vista os dvd
It more than likely won't due to it being an OS. It's usually down to copy protection.
Best thing to do is reset the PC and go into your BIOS settings, then change the boot priorities so it boots from your DVD drive, when you save these settings restart the PC. This will make the PC read from the DVD first instead of the Hard drive for the OS, should bring up a message saying "press any key to boot from disc", then when you do press something it should start up the disc and you can reformat from there.
SOURCE: Dell vostro 1510 dvd drive problem
This is likely a bad dvd drive. Usually when a DVD drive is going bad, it will first stop reading DVDs, but will read CDs just fine. I have replaced many drives that were having the same issue and with a new drive, problem is solved. It is a typical problem with DVD drives.
SOURCE: The drive does not read CDs nor can I burn a blank
make sure you cdrom is being detected by your computer. you can actually check this by going to MY COMPUTER. you should see you CDROM drive there. if CDROM is not present, please proceed with this troubleshooting.
Collapse this imageExpand this image
, and then click All Programs.
Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 8.
Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
SOURCE: dell 9150 dvd/cd drive not working
i see the D drive but it says recovery but it will no longer give me use of my dvd/cdrom but if i go into Devise manager there is a ! can't get it too work anymore not that old never dropped
help
The Dell Inspiron 531 is a desktop personal computer with a Microsoft Windows operating system. An Inspiron equipped with a CD burner can be used to record audio discs using Windows Media Player, which comes installed on the Inspiron as a standard part of the software package Dell loads onto its computers. Blank, recordable discs and pre-recorded audio CDs are the only supplies needed for the project.
Read more: How to Burn Audio CDs With Dell Inspiron 531 ' eHow.com http://www.ehow.com/how_6210098_burn-cds-dell-inspiron-531.html#ixzz1XyrRh8L7
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
