Question about Kodak EasyShare M532 Digital Camera
Operates slow why - Kodak EasyShare M532 Digital Camera
How can I fix E1 code? on the digital display?
Factory reset the slow cooker. To do this, and this is only an educated guess as no information is available in the user manual for this device, is hold the clear button if there is one while powering it off, or press the + and - buttons simultaneously and hold for several seconds to clear the screen.
Jun 07, 2015 | Cuisinart PSC-650 6.5-Quart Slow Cooker
My phone operates very slow, how can I speed it up?
there are several reason why phones work slow
the memory is too full to allow fast operation
too many icons or apps on it
mostly , operators do not keep track of downloads/uploads and the amount of supplied bits is over run so the service provider cuts the transmission rate back
May 21, 2015 | Cell Phones
My System configuration is i3 with 4GB ram. and there is only 3 softwares(ms-office,adobe reader,one medicines related software). My system became slow.
Try increasing the virtual memory setting in the windows operating system. Also see if there is a defragmentation tool on the windows operating system. I am assuming it is a windows operating system.
You may have a virus that might slow down or spyware slowing down p,c May need to run an anti spyware or anti virus program to check for these.
Dec 05, 2014 | Computers & Internet
Too slow Compaq Evo Pentium 4 1.60 GHz 256 MB of RAM
Try re-install the operating system . If windows xp you wanted, try using the first/SP1.
Most of all older machine with low spec,mostly slow . but not that slow if choose the right system operation. i suggest try install windows 2000 for better performance.
akee.4shared.com
Aug 15, 2011 | Compaq EVO PIII 1.0 GHZ 256 RAM 20GB HD...
Software slow
> software slow
Who is the manufacturer of your computer?
What is the model-number?
What is the speed of the CPU?
How much RAM?
What Operating System?
Which anti-virus software? Is it updating daily? Is it working correctly?
Which software is *NOT* "slow" ?
Which software title *IS* "slow" ?
Nov 13, 2010 | Computers & Internet
My computer is slow Carachteristics Cup: 3.2 Ram: 2 Giga Cash M: 2
Run a Disc Defragmentation: found under the start menu, accessories, system tools.
After this, under the same menu list, run a "disc cleanup".
Also, consider installing the following:
webroot window washer
webroot Essentials
You can find these at http://www.webroot.com
Please let me know if you need any further assistance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
May 29, 2010 | Microsoft Windows Vista Ultimate Edition
Slow cooker will only stay on warm. How do I put
This slow cooker has 3 settings LOW, HIGH, & WARM
When you plug the slow cooker in the display should show a "0". When you press the "COOK TIME" button, the display should go to 1 then 2 then 3 etc. each time the "COOK TIME" button is pressed. If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on the "HIGH" setting. If 7,8,9, or 10 hours are selected, then the slow cooker will operate on the "LOW" setting. To start the cooking cycle press the "ON/OFF" button. To interrupt the cooking cycle at any time, press the "ON/OFF" button. When the cooking cycle is complete, your slow cooker will automatically switch to the "WARM" setting. If the "ON/OFF" button is pressed when the the digital display shows "0", then the slow cooker will automatically start on the "WARM" setting.
If the "COOK TIME" button does not change the display numbers then unplug the slow cooker and hold both buttons down as you plug the slow cooker in. Keep the buttons pressed for a count of ten, then release them and the slow cooker should work correctly
Feb 11, 2010 | CorningWare SC60 Slow Cooker
Need fuses for samson amp
The manual recommends 4 Amp Slow blow for 115 volt operation or 2 Amp Slow blow for 230 Volt operation for the 201a.
http://s3.amazonaws.com/samsontech/related_docs/Servo201a_OM_5L_v1_1.pdf
For the 260 Amp manual shows 10 Amp normal for 115 volt operation and 5 Amp nomal for 230 volt operation.
http://s3.amazonaws.com/samsontech/related_docs/ACF1AAF.pdf
Dec 31, 2009 | Samson Audio Players & Recorders
Need a manual for the corningware sc60
The manual basically says... This slow cooker has 3 settings LOW, HIGH, and WARM. W hen you plug the slow cooker in the display shows "0". When you press the "COOK TIME" button, the display should go from 0 to 1 to 2 to 3 etc. each time the "COOK TIME" button is pressed. If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on the HIGH setting. If 7,8,9,or 10 hours are selected, the slow cooker will operate on the LOW setting. To start the cooking cycle, press the "ON/OFF" button. To interrupt the cooking cycle at any tim, press the "ON?OFF" button. When the cooking cycle is complete, your slow cooker will automatically switch to the WARM setting. If the "ON/OFF" button is pressed when the digital display shows "0", then the slow cooker will automatically start on the WARM setting.
If the "COOK TIME" button does not change the display numbers, unplug the slow cooker. Hold down both buttons and plug the slow cooker in and keep them pressed down for a count of 10. Release the buttons and the slow cooker should work now.
Nov 28, 2009 | CorningWare SC60 Slow Cooker
Kodak EasyShare M532 Digital Camera Logo
18 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
