Cleaned overflow pipe and coil. Replaced Rocker Arm and plug. Lever to empty tub will not work and plug stays closed.
The plug has a little hole in the end - that rocker-arm lever fits through the hole. If the plug gets turned 90 degrees to the side before installing the lever, the lever won't go through the holeand the popup won't pop up. Pull the lever back out, rotate the plug 90 degrees with your fingertips or thumb, and put it back in. It may take several tries.
SOURCE: Hi! Can not remove L-shaped linkage from overflow
most times it just pulls off. some times it is secured with a screw check to see if there is a screw.
SOURCE: drain plug won't stay open when the dial on the
NOT A EASY FIX,THE CABLE IS NOT ADJUSTED RIGHT,
SOURCE: I have a Kohler Overflow
Hey, I think I've got the solution for your situation.
First off, you want to get a caulk remover and apply that on all the caulking between the tub and the faceplate. Let this soak for 20 minutes. Then you will want to take a utility knife to score around the edges of the faceplate between the faceplate and the tub. Be careful not to scratch the tub! When the caulking has been completely cut through all the way around the face plate, take putty knife and pry the faceplate from the side of the tub. Check out the lever, or see if it is just gunk build up on the filter. Either way I hope this helps, and good luck!
Removal & Installation
3.1L & 3.4L Engines
Left Side
To install:
To install:
