Power getting to projector however not turning on. Press on button goes green for millisecond and then back to red.
SOURCE: Sony VPL CS5 Multimedia Projector Problem
The Temp/fan light is on and is shutting down the projector what do I do
SOURCE: Sony VPL-CS5 menu will not display
Give input signal to the projector and see that if the menu appears or not on the screen.
if menu comes on the screen then put the backgroung color to blue, instaed of black.
if nothing comes on the screen, then the LCD panels are faulty.
Viren
RAVE SERVICES
SOURCE: Sony Projector VPL-VW 10HT 2 problems 1)The
there is a lock on the projector that needs to be removed. check the manual for the code.
SOURCE: my vpl cs5 projector is 5 years old. It has no
The problem I can confirm is either one of two faults in the main power supply section.It is either one of the double diodes in the TIP type casing which has gone short, or the other most common is the main oscillator IC in the primary of the power supply.Please check the double diode first as the main IC is about twenty pounds very expensive.Please also note change the three capacitors in the primary power supply section whilst you are at it.kind regards John Williams www.jvsvisual.com engineer to the stars.
SOURCE: Sony BRAVIA VPL-AW15 LCD Projector power light
i have color bands running through the picture
Have you tried the following:
Connect the power cord and turn the projector to standby mode.
Press the following keys on the remote commander in the following order for
less than five seconds each: RESET, <,>, ENTER.
