Friend,
very easy option.
Are you on bluetooth. If not, then set this up between the two items - phone and pc. Once connected(paired) simply select file ftp (file transfer). De[ending which bluetooth software you purchased and loaded onto your pc the next step has diffferent windows. But essentially, a window with a directory from your phone is visible. Select where the files are you want to copy. Then copy. Then, paste to a new folder on the desktop of your pc.
Leave the sd card alone in the phone. The less you touch this the better. The contacts will become loose and worn if you keep touching it. Use software for running the phone apps only.
PJH1
Want to save your pics & videos from LG rumour to computer? Just connect your LG phone to computer via usb cable. Here, I'd like to share your a LG Data Manager tool. It helps us access to all pictures and videos, export them to computer directly. LG File Transfer How to Copy Data between LG and Computer
