SOURCE: I have the sharp model
To change from fraction to decimal, all it takes is a keypress. (change key)
.Not all decimal results (approximations) will be converted to fractions.
Anyway, if you want to set the calculator to display decimal results only,
Press SETUP
Press 2:EDITOR
Select 1:LINE.
SOURCE: hi! I am using the Sharp EL-735 and I don't
Setup
DSP
TAB
then you can choose between 0-9 decimal places
SOURCE: how do i do a fraction on my calculator
ok i figure this is like any other calculator, but without a fraction button. A fraction i somthing / something . so instead of the fraction button use the division button.
SOURCE: How can I convert decimal
After you perform the calculations and press the = key, you can hit the ab/c key to toggle between decimal and fraction. Try .75= then you can toggle between 1/4 and .75
SOURCE: Sharp El 546W converting decimal to fraction
You just have to hit the second button from the left, third row down. It says "a b/c" on it.
