SOURCE: Canon Image runner photocopier
error comes two types. first spares error.second normal error.first see disply which error comes.first clear all error. <* 2&8 * ><copier><function><clear><err><o k>then machine off and on maximum all errors cleared.
SOURCE: remove a paper jam under the fuser unit on a canon
Hello sir; I believe You have to detacth finisher unit then open the side door to reach the fusing unit see is there have jamming paper over there ,the paper under the fusing unit just open front door turn the knob clockwise on the fusing unit paper will coming out.
SOURCE: The ip4500 will not print - says the paper output tray is open!
Just fixed this problem on mine. Need to remove the covers, watch these 2 vids to see how..
http://www.youtube.com/profile?user=martop49#p/u/1/iQdHDR6po80
Then
on the right side where the on switch is, near the hinge is a little
switch with 2 yellow wires, it's probably broke. Pull the 2 wires out
and solder or twist them together, then put everything back together.
It will now assume the door is always open. Jobs a good'n :)
SOURCE: copy darkness problem canon image runner 2830
Did you try to clean beneath the copy glass?
On digital machines, when the copy glass or optics are dirty, copy becomes verry light.
How many copies do you have? pres 123 button.
It also could be that you need to change the toner station, by the book it goes 300000 copies.
But I bet on dirty copy glass and dirty scanner assy.Clean the glass with glass cleaner and polish it with dry cloth.
Testimonial: "so thanks"
SOURCE: my Canon Image runner 2318
is this problem only when u copy from the tray or even from bypass.if it is from tray only then ur rubber feedrolls needs to be cleaned with simple wet cloth.if it is from both then u have to check the paper path sensor
