SOURCE: frigidaire washer model FWX833AS1 top load
Hello Lcl2610.
welcome to Fixya,
My name is Huuum,
How old is your machine?
I have found some reasons of what may be the matter!
List of thinks to check
1.Defective Lid Switch
Check lid switch for proper operation. Check the switch for continuity. If it is found to be open, replace the switch assembly.
2.Faulty Direct Drive Coupling
The
Direct Drive (motor) Coupling may be broken. Many Whirlpool/Kenmore
brands washing machines utilize a small, relatively inexpensive direct
drive motor coupling. It's plastic and rubber and is mounted to the
shaft of the motor on one side, and to the transmission on the other.
It can wear out over time or fail under overloading conditions. This protects your transmission from excessive loading.
3. Faulty Water Level Switch
If the water level
switch is not resetting once the water is drain, power will not be
available to operate the motor during spin. Check the water level
4.Will not drain and displays F/02
The error code F/02 will
be displayed if the drain time exceeds 8 minutes. Press pause/cancel
twice to remove display. Check the pump filter and wiring connections
on the pump. If all looks good, replace the pump.
You may want to use a pro, rather than attempt this project your self.
Let me know how it goes!
Thank you Huuum.
Please remember to leave a rating
SOURCE: SPIN CYCLE WON'T DRAIN WATER FROM TUB IT RUNS ONTO MY FLOOR
Sounds like you have a bad water pump. Remove the hose going into the water pump and coming out of the pump and the pump should pull directly off the shaft check to make sure it spins freely.
HIm this is a faulty timer control. simply replacing this device will fix this issue.
CLICK HERE
SOURCE: frigidaire front loading washer CRTF1240A won't turn/spin
I had the same problem, we opened up the bottom front panel and found a loose connection. Electrical connector had shaken loose.
SOURCE: My washer will no longer agitate or spin. It does
check out the fill tube pressure sensor it can cause weard problems
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
heatman101
