Empty water light keeps coming on and stopping the cycle even though the condenser tray is empty and has no water in it. Model TCYM 750C STYLE (7.5Kg)
I experienced the problem with a hotpoint TCYM 750, with the red empty water light failing to switch off. After removing the filter and cleaning it, cleaning the condenser and drying anywhere I had access to the machine still didn't heat and the light remained on. Reading the post about the machine having 3 reservoirs it struck me that one of the reservoirs may be hard to access. So I unplugged the machine and tipped it onto its front. The reservoir drained, I pushed the machine back upright and cleared up some water around the condenser. The drier now works properly and the empty water light is off - job done!
SOURCE: HOTPOINT AQUARIUS CONDENSER TUMBLE DRYER CTD40
There are three water reservoirs - one at the bottom behind the condenser, a second at the back bottom of the machine and then a third at the top which is the one you would normally pull out to empty.
There is a hole at the bottom of the filter in the first reservoir (at the back of the condenser) which leads to the second reservoir at the back. If the hole gets clogged up with lint/muck then the reservoir at the back does not fill up.
So to solve this, unplug the machine, take out the condenser (front left bottom of the machine) reach through to the back and mop up the spare water with a towel and check that the hole to the back reservoir - you can feel this it is towards the right side at the back of the machine is clear from muck.
Once you have cleared it, water will flow to the second reservoir and then (once you switch on the machine) up to the main removeable reservoir at the top.
Hopefully this helps. GB
SOURCE: Miele Dryer problem
Sounds like the sensors is dirty, or there is scale or deposits in the bottle. Clean out the bottle with a descaler if it has any scale (white or brown) deposits in it. If it is clear and still a problem, the sensors is inside the bottle holding section. Make sure there is not any fluff or dirt in there by giving it a hoover outand a gentle brush.
SOURCE: indesit condenser tumble dryer water
Maybe trapped water in the dryer. Switch off and remove power from wall. Remove condenser unit from the dryer (clean the condenser while you have the chance with plenty of water and an old toothbrush - it will probably be filthy). With the condenser unit removed stick an old tea towel in the hole where the condenser was and then tip the dryer on its side. If there is water it will either run onto the tea towel or onto your kitchen floor OR into the water container!
It worked for me, honest...
SOURCE: Hoover 381/1 condenser tumble dryer empty water
Got a similar problem with an HNC172. The supplier said it is the water indicator sensor that is not working. He fixed it! It still stops!!! Clear lint from the trap in the door. Empty what little water there is in the tank, then make sure it has a good shove to get it back into place and the tube/catch is well joined back. Also take out the condenser unit above water tank, stick in the bath and put the shower hose through it to clear lint. Recommend getting a tea strainer over the plug hole or you block your drain as quite a bit comes out. It helped for a while, but it still has problems. Might be the thermostat for the heater? check the error codes. They flash a different number of times within 15 seconds to indicate which problem is happening.
SOURCE: Hoover condenser dryer VHC180. Water empty
hoover dryer water leaks when machine is running.
