Red light appears periodically - and after about an hour it goes off again.. the food is ok, but can sense that they are slightly softer sometimes.... no build up of ice inside.
SOURCE: The red light remains on...
The coils should have a nice white frost pattern evenly on the coils (no solid ice block sort of thing). If there is very little frost, or say just chunk of ice in one spot, then you may have a leak in the system where the refrigerant has leaked out. The fan above the coils should be on when the compressor is running to circulate the cold air. It does sound like you may have a sealed system leak and there's just not enough refrigerant to flash into a gas for proper cooling. Check on these items and get back to us.
SOURCE: FFA60 Hotpoint fridge/freezer Red warning light
if i read the english right, the compressor runs but the freezer fan only runs for a short time. no fan then no cooling. there is a fan stat so that the fan only runs when the evap is down to temp. this may be faulty. also on some hotpoint, the fan switches off when door opened. check door switch operating ok. this may also explain problem with fridge lamp
SOURCE: Hotpoint FFS70 fridge/freezer
water keeps appearing beneath salad bin we have checked to see that nothing has come into contact with back wall of fridge ,and we have used a straw to keep the defrost gutter drain hole clear but water still appearing beside gutter drain hole .
SOURCE: Hotpoint FFA70 Freezer High Temp
sum fans only kick on if cold enough
if the whole evap is frosted up u have a defrost problem
if frost is only partial u need to throw it out cause it either has a bad compressor or freon leak
check your fan by compressor and make sure coil isnt filthy too
SOURCE: have a hotpoint rsf60 fridge/freezer,noticed
The red warning light will not go out?
1. Has the fridge freezer just been
installed? If so, this is normal and the
light will go out when the correct
temperature has been reached.
2. Has the fridge freezer been loaded
with a large quantity of food? If so,
the light will go out when the correct
3. Have the doors been closed
properly?
