I am looking at one of these camera's on ebay
It starts up OK but comes up in the EVF as "card unusable" and you can go no futher.
what do you believe could be the problem?
It could (note I'm saying could, not is) be a bent flash card pin. If you get it, take a look inside the camera's CF card slot. If a bent pin is spotted, remove the batteries and card. Use a small/skinny jeweler's flat screwdriver to bend the pin back as close as possible. The jeweler's screwdrivers that you see at the dollar store will work fine. Another tool that I sometimes use is a stiff wire with a bent hook on the end to get very flattened pins started. Take your time and use as much patience as you can muster (take a breather in between if needed). Just keep nudging it upward/straighter a "tiny bit at a time". Whatever you do, don't try to unbend it with one push/nudge, you won't be able to do it.
It doesn't have to be perfect, just as close as you can get it. When it's the best that you can get it, take your flash card and "SLOWLY" insert it. The card itself should fine-align the pin. Remove the card, and verify that the pin is still straightened. If so, reinsert the card and try it out.
Now if you get it and there's NOT a bent pin in there (say it's a missing pin, a very different story) don't come back crying here! :-)
