THE MENU WILL NOT DISPLAY TO SET THE SETTINGS FOR THE PLAYER TO PLAY ON THE SAMSUNG BUT IT WILL PLAY ON ANOTHER TV
SOURCE: Black Bars on all blu ray movies
Hi icmjrtdr,
Having black bars displayed when watching a Blu-Ray disc is a common occurrence, even with a widescreen television.
You may have heard or seen aspect ratios of 4:3 or 16:9. 4:3 is the ratio of a traditional television that is nearly square. 16:9 is the ratio of most widescreen televisions currently marketed. The reason that even with a 16:9 television Blu-Ray discs are displaying black bars is that many of these discs contain footage that has not been reformatted for television. The screen in a movie theater is even wider than 16:9, and rather than trim the ends, most Blu-Ray discs maintain the entire picture.
Depending on the options available in your particular television, you may be able to find a zoom setting that trims the ends and removes the black bars. It is up to you if you would rather see black bars with the entire picture or lose a small amount of the picture on each side for a full-screen experience.
Hope this helps,
Jason,
Go Ahead. Use Us.
SOURCE: Need code for included blu-ray universal to work with an Olevia TV
if Samsung never included the brand Olevia on there remote, then its not going to work because it was never design to work with that brand. The only way to get around that is to get a learning remote or universal remote that has olevia pre program into the remote.. Olevia did come out with some learning remotes that is able to learn from other remotes.. the model its called Olevia RC-LRN ..
This company called Amergence Technology sells the RC-LRN remote made by Olevia contact them at this toll free number 866-965-3842
SOURCE: When trying to connect my 4695D to a new Sony Blu
The problem has been solved. A previous post to this site was having a similar problem hooking up a Playstation Blu Ray player to the same TV.
A solution was posted to that problem and I followed the same instructions.
It has to do with the set up porgram on the Blu Ray component. You need to select Settings then 108024Bit needs to be set to off.
SOURCE: CAN'T PLAY BLU-RAY DVD ON SAMSUNG DVD BLU RAY PLAYER
I have a Samsung BD-P1600 and was having similiar problem...played thru previews but would not play. Instead of just powering off/on... I pulled the plug on the ac cord out and left it out about 20 minutes and it now works !
Testimonial: "Thanks for responding. It's working!"
Please dont forget to vote if you liked my answer
thanks
