Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
I have a Frigidaire stacked unit that I bought in 2005. The screws in the dryer drum keep falling out, their are 3 screws I have lost one, one still in and one I found in my clothes. The unit has caught fire twice from a spark when the screws fell out. Anyone else with this problem?
  • 38 Answers
Take one of the screws down to your local hardware and buy new ones and lock washers (with teeth on the inside so clothes won't catch on them).
Good Luck
Quentin
Posted on Oct 04, 2009
6ya staff
SOURCE:
I have a stacked Frigidaire FEZ831CA washer/dryer combo and when running the dryer it makes a very high pitched (AND LOUD) screeching sound. Any ideas as to what might be the problem? Thanks, Sean
screeching sound
Sean, Bad felt gasket body to drum, if belt drive on dryer, it could be worn and slipping, making a screech, or if not the belt, the drum may have a worn bearing on its hub allowing it to run crooked and rub where it should not.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Disassembling reassembling stacked clothes dryer
Frigidaire Stacked Laundry with Noisy Dryer
How to Replace an Electric Laundry Center Dryer Drive Belt Kenmore...
Mar 29, 2016 | Frigidaire Washing Machines
Frigidaire stack dryer was squeaking so bad that I decided to take it apart to see why - noticed it was the socket at the back .. I oiled it, put it back together but my husband and I cannot get the 3...
The drum was not positioned correctly to allow installation of the screws. You may be able to salvage the job by removing the screws and starting over but more likely the screws have been cross-threaded and hardware and parts replacement may be necessary.
May 01, 2014 | Dryers
Frigidaire FEQ332 dryer: I (stupidly) removed the 3 center screws from the inside rear of the drum (in a vain attempt to clean lint from the back) and now I can't get them back in. The dryer is a tight...
well first turn the power off without those screws there is a chance you can arc the drum out agianst the element second you have to get at least one screw back in then rotate the drum slowly to line up the other holes do not run without the screws can cause some major damage
Jun 02, 2010 | Frigidaire GLEQ642A Electric Dryer
I have a Kenmore stack washer/dryer. There is
you have to go in through the front and a total of 5 screws
Aug 08, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Electrolux FGX831FS1 dryer drum, only spins one way manually
Check inside the drum to make sure the three screws in a triangle in the rear center are all there, if they fall out the drum goes off center and the motor can no longer drive it.
This model has no rollers, the front of the drum has plastic glides mounted on the front of the drum that ride on teflon impregnated pads that are glued around the door.
The rear is supported by a steel ball screwed to the rear of the drum (the 3 screws that I think are causing your troubles) that rides in a plastic saddle screwed to the rear of the machine.
If the excess drum movement is only up and down you should replace the front glide system.
Good Luck
Quentin
Apr 26, 2009 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire combo washer/dryer screws inside come off
The drum shaft came loose from drum. You can YouTube it for procedure of disassembly of dryer. Remount shaft, if screws are bad may need new shaft with screws, make sure it is tight to drum. While you have it apart you can clean out lint.
Sep 27, 2017 | Frigidaire GLER331A Electric Dryer
Dryer won't spin on my kenmore stacked model 417.90812991
This is the 2nd time I have this problem.
IF you look thry the drum to the back you should see 3 screw heads. Mine has one screw still in the hole and 2 empty holes.
This requires the drum to be removed (like take the drier apart). Behind the drum is Asmbly-shaft (ball hitch) (item 32 in the parts list). This what the 3 screws screw into.
I spent 2 days trying to put the screws in without removing the drum not possible (no way to hold the drum in place)
The first time I had to replace the drum because it wore the rim through.
I have to get 3 new screws and some thread locker.
I recommend that you check the screws every month, Use a long phillips screw drive
Nov 02, 2008 | Kenmore 94812 Top Load Stacked Washer /...
Fridgidaire GLET1041AS1
Unplug unit! Remove top screws and pull off top lid of dryer. Heater terminals should be at top right. Use ohm meter to check resistance. If ohms won't display, then your heater unit probably has an open circuit. For instance, my GLET1031 has a reading of 12.5 ohms.
Sep 30, 2008 | Frigidaire GLET1031 Top Load Stacked...
FLSE72GCSA top drum glide
remove screws holding console on ..2 on bottom rail and 1 in each lower corner of console they are recessed .console will drop slightly and off 1 screw in each corner of front panel be sure to not loose them they go in these spots only..flat heads..recommend removing large front panel between 2 units remove blower housing 2 clips or screws each corner lint screen housing on inside..reach through and remove belt this will make reassembly easier by removing downward pressure on drum ..
Jul 04, 2008 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
149 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
