When I push the wps button on my linksys wrt54g2 v1 it does not blink while setting up Philip smart tv
SOURCE: i lost my linksys wrt54g2 v1 cd i need to install
http://www-ph.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=PH%2FLayout&cid=1166859837401&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=3740141396B01
SOURCE: i need installation software for a linksys WRT54G2
router do not normally need installation software..
you can access their admin software by putting in the ip address into your browser...
if you are running xp go to start > run and type in "cmd"..
when you get the black DOS screen, type in "ipconfig" and look at the results for the ip address of your "Default Gateway"..
go back and type this into your web browser to access the router...
for linksys the default password is admin, leave the username blank
SOURCE: linksys wrt300N wireless light not blinking
the wireless connections says limited or no connectivity when it does not get IP address from the router.
There might be problem with the wireless settings of the router.
if your network is a secured network then you will need to check the network key.
You can try to upgrade the firmware of the router. that will be a good option.
Click Here for step by step solution
SOURCE: i lost my start up **** for my linksys wrt54g2 v1
You can download it from here,
http://homesupport.cisco.com/en-us/wireless/lbc/WRT54G2
Select XP, Vista Setup wizard download.
Don't forget to give me a good rating as well as your vote.
SOURCE: linksys model no wrt54g2 v1
This is the direct link to the Firmware update simply scroll down and under Firmware click download.
copy and paste into address bar.
The Linksys WRT160N has WPS (Wi-Fi Protected Setup). If you are using WPA-PSK encryption (recommended), then you can easily connect the C4780 to your wireless network using WPS:
1) On the Linksys router, press the WPS button that is top of the case just under the Cisco label. When the LED on the button starts to blink, then the WPS process has started.
