Pictures is over saturated and washed out on any input device. factory reset, no change.
SOURCE: Samsung LCD Tv
Try this:
Access menu service by press on your command, with your TV OFF:
INFO + MENU + MUTE + POWER ON
Then you should get access to Service Menu.
The last item says: RESET
This will do a reset to the TV.
Make no harm.
WARNING: If when on service menu you feel tempted to "screw" on anything FIRST take note on ALL you change! You can compromise the TV ...
SOURCE: Picture washed out, can't get it right
LCD TV TroubleshootingThe defective LCD TV may have the following common symptoms:
Symptom: No picture on screen but LCD TV still has sound.
Solutions: The problem is cause by defective inverter. Replacing ivnerter will solve hte problem. Symptom: Screen flash on and off between 1/2 to a few seconds, but power indicate light stays on and TV still has sound.
Solutions: The problem is cause by defective inverter. Symptom: Blue Screen but no picture
Solutions: The problem is cause by defective Main Board(AD Board). In some cases, this problem may cause by the defective Screen Controller board. Thsi board is mounting on teh back of LCD TV Scree. Symptom: Power light stays on but no display and sound
Solutions: The problem is cause by defective Main Board(AD Board) or Power supply board. Symptom: No Power or Power indicate light does not lits
Solutions: The problem could cause either by defective Power supply board or defective Main Board(AD Board). Symptom: Screen is half dim and half bright
Solutions: The problem is cause by defective LCD Panel.It needs to be replace.
SOURCE: Rainbow color effect appears when Samsung LCD plays Wii or DVD
Hello, I have a question which video inputs are you using for your DVD and Wii connections? The reason I ask is because this sounds like video distortion cuased by noise. If possible can you send a picture of the screen when it has this problem and send which video ports are being used? If it is noise in the video you may have a saw filter problem, or a decoupling issue. In any event I'll know more once you send those pictures and which inputs you are using for your DVD and Wii. Thank you, Shuttle83 http://www.electron-age-technologies-llc.com [email protected]
SOURCE: Samsung LCD -no picture/sound from any input source-Cable,DVD,PS3
Use the menu button in the front screen of your tv.Maybe your remote control need a battery.
SOURCE: Samsung Le40a556 factory reset
with tv in standby press INFO / MENU / MUTE / STANDBY on remote the tv will come on in factory menu settings look for reset use DOWN NAV KEY until highlighted and press RIGHT NAV KEY
to exit settings press standby the tv will come on and follow on screen instructions
DO NOT CHANGE ANY OTHER SETTINGS TV WILL NOT WORK IF CHANGED
Summary of picture settings
The following picture settings can be confi gured. Depending on the
format of the picture source, some picture settings are not available.
• [Auto Picture]: Sets all picture settings to the factory default.
• [Brightness]: Adjusts the intensity and details of dark areas.
• [Contrast]: Adjusts the intensity of bright areas, keeping dark areas
unchanged.
• [Color]: Adjusts color saturation.
• [Tint]: Adjusts the color balance in an image.
• [Sharpness]: Adjusts the level of sharpness in image details.
• [Color Temperature]: To set the color temperature to [Normal],
[Warm] or [Cool].
Summary of sound settings
The following sound settings can be confi gured. Depending on the
sound source, some sound settings are not available.
• [Auto Sound]: Sets all sound settings to the factory default.
• [Equalizer]: Adjusts individual sound frequencies.
• [Virtual Surround Sound]: This selects the modes for more spatial
or surround sound reproduction.
• [Auto Volume Leveling]: Reduces sudden changes in volume, for
example, during commercials or when switching channels. Select
[On] or [Off].
• [TV Speakers]: Select [On] or [Off], or output sound to an
EasyLink compliant device. When [Speakers EasyLink] is selected,
the TV speakers are disabled and TV sound outputs to the speakers
of the compatible EasyLink compliant device. Adjust the volume
using the unit's remote control.
OK.
