Will not reset by turning on or off. hard error
SOURCE: resetting code on a copystar cs-1620
what code? many codes to be reset such as 1087 1087 then enter163 to reset fuser. you need to know what your resetting first, some machines used 096. let me know what you resetting. rrralf
SOURCE: copystar 2014 UF error code need help
Take Out Toner Cartridge. Looking straight through there should be a tiny switch that tells the machine there is a toner cartridge present. It might have just gotten out of position or may be broken, which means you'll have to replace it!
SOURCE: Copystar 2221, C30 code
Hello sir; I believe your error code should be C030, if that's correct that 's mean main board is bad , it not worthy to repaire it, go buy a new machine.
SOURCE: Error code c6300- How do you reset this copier?
Enter the service mode and enter reset code 163.
