Question about American Standard Home
Toilet gurgles We have a new American standard glen wall wall mount toilet which replaced the original one after 44 years. Shortly after ins it started with this problem of loud gurgling. We thought it was related to the washing Mach or dishwasher running at the same time bUt it happens at random times when nothing else is running. My husband is a licensed commercial plumber and is unable to figure out what t.his is from. We even called the manufacturer who didn't know what we were talking about-- HELP.
6ya staff
SOURCE:
Anonymous
  • 116 Answers
SOURCE: siemens hydrosensor dishwasher SE25A091GB/22
Paul
If you are still trying to sort out this issue try the following.
From what you say then it is most likely the aqua sensor on the side of the dishwasher. The gurgling sounds that you hear are likely the drain pump running and the un-drainable water sloshing in the sump.
Verify that there is actually water going to the dishwasher( Basic step but often overlooked)
Next the inlet valve will have to be checked. This is the part where the water line from the house connects to the dishwasher, under the toe/kick panel. Remove power from the dishwasher. Disconnect the dishwasher electrical connections (2 wires) to the inlet valve and connect it (carefully to 110 V power) using a jumper wire. With 110V power the valve should open and water will flow into the dishwasher, if not then the fault is in the inlet valve.
If this checks fine then the fault is likely in the aqua sensor...
On the outer left side (viewed from front) there is a panel, Behind this panel there is a small clear(of light blue) plastic mechanism with hoses and wires attached( There is usually a yellow disk at the top about 6cm in diameter) this is a float and sensor assembly there is tells the control the water level and works as an emergency drain if there is an issue. There will be a red stick protruding downward to the base and a Styrofoam float on which the stick rests. This is a pan overflow sensor if the stick is too high the unit will go into drain and cut off the fill valve power. The yellow disk is a diaphragm which senses water height. This unit can become stuck with wear and hard water.
Posted on Jul 28, 2008
douglas smith
  • 1462 Answers
SOURCE: Sub-zero 650 makes loud gurgling sound
gurgling is not unusual and is caused exactly by fluid bubbling thro a pipe.
Posted on Nov 04, 2008
Jim Franks
  • 374 Answers
SOURCE: how to replace a commercial flush valve
These used to very simple but have become more complex as technogy evolves. I will give you the standard answer though.
First shut the water supply off to the aplliance (there is a little decorative cover on the valve that is attached to the water line coming out of the wall. It looks like a nut. Pop this cover off and screw the screw in remember right is closed and left is opened.)
Now it is only a matter of unscrewing the couple of nuts that attach the actual valve.
Most valves come with step by step instructions but even without them it is usually a 30 minute job or less. You will need a flat head screw driver, spud wrench, tubing cutters- to cut the chrome trim tube to size, and some pipe thread compound or teflon tape.
Thanks for using Fix Ya and if I can be of further assistance let me know.
Jim
Posted on Nov 10, 2008
djchillsnyc
charlie rodriguez
  • 152 Answers
SOURCE: have to flush 2 or 3 times to empty toilet bowl
hello, this is a standard toilet you will need to inspect the flapper that is the rubber flap that holds the water up in the tank it works when you pull the lever it pulls the chain upward and lets the water flow if this flapper is old it may not stay up long enough for the water to flow. open the tank top and flush the toilet see if this flapper is staying up long enough and giving the tank enough time to empty if not change this rubber flapper its inexpensive part.
if this is not the reason then you need to adjust your water filler valve there should be a small screw on top of the pivoting float arm
if you have to adjust it for the water limit line inside the tank this will be the proper amount of water needed to flush once completely
also check that the chain lenth on the pull lever is not pulling the flapper down quicker than its supposed to,
try this let me know your results
hope it helps
Posted on Dec 15, 2008
Donni Steen
  • 687 Answers
SOURCE: flapper will not go down
Troy, the flapper otherwise known as the flush valve is easily replaced. They are also very inexpensive. Sometimes they can become distorted due to the clorine in the water and won't operate in the same way they did when it was new. I bet this will fix your issue and save you money as well.
Posted on Mar 21, 2009
Bought 2 American Standard toilets model 4149A and the flush levers have been cutting us. Can we buy new handles
Yes you can replace the handles as they are available from American Standard, directly. Go to their web site, parts and service, and select you mod. toilet. Order from them. https://www.americanstandard us.com/bathroom/toilets-category
Feb 05, 2018 | American Standard Home
What causes a loud gurgle after flush?
If the flapper does not seat correctly and completely, refill water flows into the bowl and causes a "false flush" and the loud gurgle. You can demonstrate this by holding the flush handle depressed after a normal flush. Also, there may not be sufficient slack in the flapper chain to allow it to seat correctly.
If the flush valves were installed exactly according to the instructions, they should work perfectly and can be excluded as a source of the problem.
Jan 23, 2016 | Home
Hi, I want to replace an old American Standard toilet bowl that is a 4 bolt tie down design to the floor. Can I replace this with a standard 2 bolt floor mount design? If not are 4 bolt tie down models...
If you go with the 2 bolt you will need (I presume) to drill 2 holes into the tile. put toilet in place where it will sit and mark the holes , take away toilet and drill the holes with a 7ml tile drill bit (masking tape put over the tile will help you to not slip when starting off the hole). Drill deep enough to insert 7ml rawl plugs. then place the toilet back and fix down with screws long enough to go through the toilet and 3/4 of the rawl plug. You will need; Electric percussion drill or descent battery drill. 7 ml tile drill bit 2 x rawl plug 7ml 2 x screw masking tape is handy hope this helps, Alex
May 18, 2011 | American Standard 2294.011.020 Afwall...
American Standard toilet rear gasket is leaking
Check that the two bolts holding the tank are tight, if they are then remove tank and replace the gasket
Nov 06, 2009 | American Standard Glenwall Pressure...
We have american standard toilet model 4260 that runs all the time. have replaced seal twice. toilet is only 2 1/2 years old. what do we need to replace?
if it doesn't fill, it's your flapper, if your tank is full then you'll need to adjust the float. take a look on amazon for those 2 parts, and read into reviews. here: Modern Shower Doors at Amazing Prices. cheers
Sep 19, 2009 | Home
I hear noises and feel vibration from the wall behind the toilet tank. When I lift up the toilet water tank cover or flush the toilet, the noise and wall vibration stops. However, the same noises and...
Your ball **** needs replacement (water control valve), Also your flapper or tilt valve disk is leaking water through it and it needs replacement also.
Sep 09, 2009 | American Standard Toilet Tank ...
My American Standard toilet flushes okay but when it is filling up the water will not stop running unless I lift the top and depress the lever.
Replace the fill valve. You can pick one up[ at Home dep or Lowes for about 20 buks. Close your angle stop at wall behind toilet. Drain all water from tank then remove supply loine from under tank. Then unscrew fill valve and remove gasket and all. Remember to put gasket in new one. :)
Sep 07, 2009 | American Standard Colony 2388.012.222...
Wall-mounted toilet has a crack and is leaking. Can a ceramic toilet be glued and with what?
If you don't care about seeing the repair use the product that Smithbrother recommended it works great. Other marine epoxies would also do it. They can be purchased in any hardware store, including the box stores like home depot and lowes.
Mar 14, 2009 | American Standard Home
American standard cadet 3 leaking around seal
get a new filler assembly. the water in the tank is heavy enough to close the seal completely. or the rubber seal is not making contact. thats' why the leak.
change the whole assemble ususally correct the problem.
adjuste the flow to about 1/4 to 1/3 under the over flow. if that still don't give you the pressure. you ca adjust the flow tube to 1/5 under the cover. that is the max.
Oct 28, 2008 | American Standard 2294.011.020 Afwall...
Home Logo
37 people viewed this question
Top American Standard Home Experts
US Parts Center
US Parts Center
Mike
john h
Are you an American Standard Home Expert? Answer questions, earn points and help others
