SOURCE: is it possible to use an SD memory of 1 GB in Optio 555
I didn't realise there were issues. I have a Corsair 1Gb SD card in my Optio555 and I've never had any problems.
SOURCE: 4gb Memory card error
In order to use 4gb memory your camera has to be approve for SDHC use.
If it isn't the most memory you can put into your camera is 2 gb
SOURCE: Kodak 4 GB SD card (brand new) shows "card error" in Pentax optio
Hey,
The problem is your camera doesn't work with the 4gb card, its too big. Sorry!
Your stuck with 2gb cards. Id suggest to echange the card to two 2gb cards.
Let me know if you need anything else.
Thanks,
Ekse
SOURCE: Memory Card Error on 4 Gb CF cards (80x) for Pentax Optio 430
The maximum supported memory for Pentax Optio 430 is 256mb and for Pentax Optio 430 RS is 512mb.
Check this site for more information.
Optio 430
http://www.upgradecomputermemory.com/ram.cfm//memory/P/Pentax/Pentax-Optio-430/
Optio 430 RS
http://www.upgradecomputermemory.com/ram.cfm/memory/P/Pentax/Pentax-Optio-430RS/
SOURCE: Optio E10: memory card error
if the cards work ok on something else then there's a issue within camera it could be the actual sd connector within the camera ? doess the camera support that size ? Optio E10 supports upto 1GB SD Card http://www.pentaxcanada.ca/pdf/o_manuals/om_OPTIOE10_e.pdf it might not work with the high speed sd cards ? Regards
