NEC Electra Elite DTU 16D-2 Corded Phone Logo
A
Anonymous Posted on Feb 03, 2014
The display needs to be darker - NEC Electra Elite DTU 16D-2 Corded Phone
I have a LCD SAMSUNG TV MODEL LN46M81BD S , and am trying to figure out the problem that it has. What happens is that everything is working properly, the tv image is seen and heard but problem is that...
The first thing to do is to go into settings and Reset Picture Settings. If that doesn't fix it, you will need to take it to a repair shop for diagnosis and repair.
Dark Screen and Blue Lines Arc Across Background
Hello!!
If the coolant is cloudy or has debris floating in it, the coolant will have to be changed and the lenses and crt face will need to be cleaned. Coolant can be ordered from any electronic distributer
Background dark
Hello Roberto
Same with my Viera plasma. Some channels re-broadcast shows or movies that look darker. I believe it is the station that is doing that since they looker darker on my TV, yours, and on LCD TVs too. You could possibly brighten your display by choosing different settings in your menu... but what your TV is displaying is correct. It is the broadcaster that perhaps decreasing the signal... since other stations look fine I assume.
Jeff
Dark line down the middle of my flat screen tv
Most LCD and PLASMA sets use two boards (some combine them into one board) that drive the Display Panel (the entire front screen unit) so I would suspect one of yours is bad.
The other unpleasant possible cause is where the left board is connected to the Display Panel (entire front screen unit) you have a problem inside that Display Panel and that is fatal as there is no way to get INSIDE the panel---it can cause both lines and a dark picture on one side of the screen.
Why is my picture darker than normal
It may be the backlighting has been readjusted by someone other yourself. Whenever you go on battery, I'm sure you've seen the screen darken a bit. This is the backlighting being turned down to save battery life. There is usually a blue function "fn" key that allows the user to brighten or darken the display. Look at the blue icons in the F1-F12 keys. The one to brighten the display looks light a sun and the one to darken the display looks a full moon eclipsed. Press and hold the fn key and tap the desired function key to brighten or darken the display.
Ipod touch 1st generation display very dark
You probably reduced the brightness one time, but you just forgot about it. To make the display brighter, do this:
>on your iPod touch screen, go to Settings.
>once the Settings window is open, you'll see Brightness from the list, tap on it.
>now, you drag the button to make the display darker or brighter. drag it to the left to make it darker, to the right to make it brighter. You'll notice the display darkens / brightens simultaneously as you drag the button.
For more iPod touch / iPhone tips, click here. Feel free to comment on my tips if you have other questions.
A Dark Bar at the top of the screen that looks pink against white
the light engine is defective if you have black bars that look pink.
Toshiba 57LX177: Right side of screen darker than left
I am not sure...but I have the identical problem. I believe the vertical lines are caused by the inverter board and the darkness is caused by the one of the back lights that needs to be replaced. I am tearing my unit apart now and will find out.
Display probs
Sorry, I can't really help you on the one, all I can say is that I have the exact same problem but it's intermittent. Very strange, sometimes it'll only be on line or two...sometimes they're darker than the screen and sometimes they're lighter...
Top NEC Lands Phones Experts
ADMIN Andrew
ADMIN Andrew
Don A
Don A
RAJA NADEEM AKHTER
RAJA NADEEM AKHTER
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
