I am trying to wipe a this computer for a friend of mine and it keeps coming up to put in a System Restore CD/DVD #1. I don't have any disks. It looks like someone tryed to start a system restore because it automaticly sayes completing recovery partition, then asks to insert a disk. Is there a way to reset the system recovery or is it a dead horse?
SOURCE: eMachines eMonster 500A Restore Disk
I suggest finding the specific drivers that he deleted. Typically, when a computer begins to get slow, either 1 of 3 problems occur. 1. The drivers are insufficiently up to date. 2. There's too much clutter on the hard disk, RAM, and CPU. Lastly, driver files and start up files get deleted. The best way to fix that slow problem is downloading the driver files.
SOURCE: emachines t5212 system restore backup files, please help!!
If you only your files to be copied in the other or any storage disk then you can remove the hard disk of your machine and then attached it to the other functional machine. in there you can browse and copy all the important files. after copying all your files then you can take back the hard drive to your non functional machine and then install new operating system. documentation found here: http://support.microsoft.com/kb/316941
tell me if something wrong with your system when applying the solution.
melnavz
SOURCE: Restore CD will not load
I bought an emachine EL-1200 in february 09. I go to the menu and hit start normally but the computers shuts back down. Can anyone help me with this problem?
SOURCE: E-Machine T2893 keeps restarting after rest=ore
I don't think the problem is with the motherboard. It's likely that you have a corrupt Windows installation and that reinstalling Windows will fix it. Unfortunately reinstalling Windows will also erase any data you have on your hard drive. Do you have access to another drive that has windows installed already? You could try installing the other drive to rule out a faulty motherboard, but I think it's likely a Windows problem.
SOURCE: I insert restore disk and nothing happens
Hi there.
If you don't have the option of hitting F12 to change the boot order to the CD/DVD just as the computer starts up then you will have to enter the bios to change the boot order.
Restart the machine and hit either Del or Esc to enter the bios, look for the boot order and set the CD/DVD as first boot device, hit F10 and exit the bios, the computer will restart and you should now be able to boot from the CD/DVD.
Please post back with the results and if you need anymore help.
Good luck and thanks for using FixYa!!
Use a memory device such as a rewritable DVD or external hard drive to back up the data you need to save from your eMachines computer. Any data that isn't saved to an external source will be erased when the computer is restored to factory settings.
Remove any discs that are in the optical drive and unplug the computer's peripheral devices, such as an Ethernet cable or scanner. Do not disconnect the keyboard and mouse. Bring up the "Start" menu and choose "All Programs."
Navigate to "eMachines" and then "eMachines Recovery Management." Click the tab labeled "Restore," which is located at the top of the window.
Click "Password Settings" if you have not already set a recovery password. Type a new password in the text box and then click "OK." Click "Restore System to Factory Default."
Type the recovery password and click "OK." Click "Next" to wipe the eMachines computer's hard drive and begin the recovery process.
Select "Finish" and wait for the eMachines computer to restart. Use the series of installation prompts that appears on the screen to create a new user account for your operating system, set the system date and time, and set up your Internet settings.
Click the "Start" icon on the Windows Vista home screen. Select "eMachines," then click "eMachines Recovery Management." The eMachines Recovery Management program opens.
Click "Create Factory Default Disc." The program will tell you how many discs you will need. Make sure the correct optical drive is selected, then insert a blank disc into that drive. Click "Start" to begin the burning process.
Remove the disc when it is finished burning and label it "Recovery CD 1." Insert the next the next blank disc if one is required. Click "OK" to begin burning the next disc. Repeat this step until all of the discs have been created and labeled. Close the eMachines Recovery Management program, insert the system CD that came with the laptop and restart the laptop.
Press "F12" repeatedly when the eMachines logo is displayed on the screen to be redirected to the Boot menu. Select the optical drive, then press "Enter."
Insert Recovery CD 1 when you are prompted to insert the recovery disc. The eMachines Recovery Management program will open.
Click the "Restore" tab in the list on the left side of the eMachines Recovery Management program window, then select "Completely Restore System to Factory Defaults." The computer automatically restarts and the recovery process begins. Insert any additional recovery discs as requested. The computer will reboot automatically when the laptop has been recovered to its original factory default settings, and you will be taken to the Windows Setup screen.
Set up Windows Vista with your own personal settings.
