SOURCE: COMPATIBLE GRAPHICS CARD WITH P5GC MX/1333 ASUS
Yes you can put a 1 gb card. The motherboard has PCI Express so you don't have to worry to much. The older AGP cards are almost gone.
You could buy a GeForce 8500, 8600, or 8800, or the 9 series. You can also buy a Radeon HD 5870 or 5570.
If you need further assistance, please post. And do not forget to rate.
Thank you for using FixYa
SOURCE: COMPATIBLE GRAPHICS CARD WITH P5GC MX/1333 ASUS MOTHERBOARD.
Hello you can read the spec.here:
http://www.asus.com/Motherboards/Intel_Socket_775/P5GCMX1333/#specifications
Your mainboard uses PCI-E socket this is the new standard for graphic cards.
Your local computerdealer can advice you a good graphic card
but it depends what you have to use it fore.
If you use the pc to seach at the internet a cheap card will be great
but if you use the pc for games you might have to spend 200 dollars.
Good luck
Testimonial: "Thank you..I'll try for sure>>>:) "
