HP Compaq d530 SFF PC Desktop Logo
A
Anonymous Posted on Feb 03, 2014
Sound driver vista - HP Compaq d530 SFF PC Desktop
1helpful
SOUND CARD NOT INSTALLED IN MY SYSTEM AS I DONT HAVE RIGHT DRIVER FOR THE CHIP SET k8S MX ASUS MOTHER BOARD AS THE SOUND CARD IS ADI AD 1888 SOUND MAX. WHERE CAN I GET THE DRIVER FOR WINDOWS VISTA
If you are running Windows Vista,
and you have the soundmax AD1888 Chipset,
you have no sound in Vista . . . relax, this problem is common.
Try the following soundmax AD1888 Drivers in this torrent.
You will find 2 maps in the downloaded file.
1) Use the swsetup, there is a setup.exe in it, install, then reboot your pc. You should have sound now.
2) If this does not correct your problem,, update your driver using device manager,
with the other map (Vista-Driver-Vista)
This has worked in nearly every instance :-)
Follow this link below to the file. Please be sure to provide appropriate feedback for me if this helped!
http://dl.torrentreactor.net/download.php?id=1827037&name=Vista-Audio+%28Soundmax+AD+1888+Drivers%29.rar
Vista driver for mustek scaner 1200 ED
There is no official driver for mustek 1200 for vista, due to it's age, but you can try installing the one intended for XP from: http://www.mustek.com.tw/Download/driv_scanr/europe/1200ed.html .
As far as I know, you don't need special drivers for HP Deskjet printers in vista, due to system having integrated drivers. But in case that the system doesn't recognise the device you can try with xp drivers (since there are none officially for vista) from: http://h10025.www1.hp.com/ewfrf/wc/softwareList?lc=en&dlc=en&cc=emea_africa&lang=en&softwareitem=dj-14939-2&os=228&product=375447&
Soundmax vista driver:
http://drivers.softpedia.com/get/SOUND-CARD/OTHER-SOUNDCARDS/Analog-Devices-SoundMAX-AD1988-Vista-Driver-610026110-WHQL.shtml
I have LG lm70 express it was have sound till i installed windows vista now no sound
You need to have a Vista driver installed  for your sound  sound. Below is the web site that lists all of the products that have Vista drivers available for them. I coudl not find you product but maybe you wil have better luck. If not maybe the only answer woudl be to  buy a different sound card with the Vista driver for it.
http://support.creative.com/kb/ShowArticle.aspx?sid=14186
Cant find sound driver for K8V-MX motherboard for vista
Parth,
Unfortunately ASUS has not written drivers specifically for Vista.
It could be that the sound chipset is INCOMPATABLE with Vista.
But before you give up try Win XP's and Win 2000's driver (They do share SOME architecture with Vista and just might work.
If that fails you can type in your soundcards name (Soundmax) and "Drivers" into your preferred search engine and see if someone has written a third party driver for it.
If this fails, I'm sorry to say it looks like your options are limited.
1.) Get anew sound card. There are some very affordable ones on the market
or
2.) Give up on Vista and put your previous Windows back on
Hope this helps
Dave
2helpful
3answers
3answers
How to download acer aspire 5920 sound drivers
http://support.acer-euro.com/drivers/ftp/ftp.html this is the site where you can download your drivers for Vista. since you didn't mention your OS I presume it's Vista.
2answers
Sound driver
Is this an OEM install of Vista or an upgrade. Several legacy sound cards, especially the integrated Realtek cards have had compatibility issues with Vista. Some of these can be resolved with a firmware update, some can't.
Audio files for vista
Hi
it is a problem with sound Drivers.
You need to download / install the sound drivers which are comfortable with your motherboard configuration in Vista
Also please note most of the motherboards supports Realtek Sound drivers
You can download the latest version for vista drivers directly from Realtek website
http://www.realtek.com.tw/
3answers
SOUND CARD
you have laod sp2 .sp3 is no sound it is some problem in sp3 ..........
Audio - Vista 32Bit
There only drivers written for
SoundMAX Audio Driver version 5.12.01.3663 WHQL driver for Windows 98SE,ME,2000,XP
No VISTA yet.
You can call ASUS and ask them if they are planning to write them,or pick up a new sound card that will be compatible with VISTA.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
