SOURCE: canon powershot g5 - battery charge
Take out the battery and put it back and than recharge again. Some times in case of G5 it happens that the camera battery is not properly charged and the indicator shows that its fully charged (i.e. Green light) In such cases battery need to be taken out and than put back again and recharged
Regards,
Zain
SOURCE: Powershot A720 Date Function
Do you want date/time stamp?
If so, you will have to be in postcard resolution.
To achieve this you will put your camera in shooting mode, hit function/set button, arrow down to bottom left corner where you will see L, M, S and postcard modes. Select the one that looks like a postcard.
Hit function/set to get out of there. Now hit menu and go to setup menu (tools) and arrow down to date stamp and make sure it's on date and time.
images shot in this resolution will look good as 4x6 prints, but should not be printed any larger or they will look pixelated, not good quality for larger prints.
Either that or you can add date and time in the Zoombrowser program that came with your camera should you need larger prints with date/time stamp.
I hope this helps!
SOURCE: Remove battery door of Canon A630
This is an old A70, but the way it's done is very similar as I don't think this has changed much over the years. It's a pin design that you have to push out with a stiff unbent paperclip. You push in on the side with the smaller hole. To access the pin you'll need to remove the front and back case covers. See the following:
http://blog.thustra.com/2007/03/canon-a70-ir-modification.html
SOURCE: Canon powershot S50: Sliding door stuck.
this can happen,gently tap the door(GENTLY) may loosen it works on my a70
SOURCE: Canon Powershot SX110is: problem with the batteries
Make sure you are using Lithium batteries. Alkaline batteries will go dead immediately in this camera. I've tried it.
