HP LaserJet CP1515n Printer Logo
A
Anonymous Posted on Feb 03, 2014
Pcl xl error insufficient memory - HP LaserJet CP1515n Printer
2 Related Answers
syed mahmood
  • 77 Answers
  • Posted on Dec 16, 2009
SOURCE: PCL XL ERROR
re load the software and check the buffer system
mohideen bava
  • 199 Answers
  • Posted on Aug 02, 2011
SOURCE: error on printer pcl xl error, insufficient
reinstall the printer pcl6 driver
HP L7680 Error
  1. Check the cables connecting the printer to the computer and make sure they are secure.
  2. Turn the printer off and back on.Resetting the printer can sometimes bring it back online.
  3. Check the toner or ink cartridge. If your ink is low or empty, the printer won't function.
  4. Check for torn paper, paper clips, sticky label residue and other items that could be the cause of error
Home HP Printer Troubleshooting and HP Support Number hpcsupport org
Pcl xl error error: insufficient memory operator: rectanglepth position : 751 How do i correct this problem
Solution
The possible reasons for this error message are as follows:
  • The document is containing both image and text.
  • The font is not supported.
  • Embedded fonts are used.
  • A special plug-in is used.
This issue can be fixed by enabling the following option in Printer Preferences .
To access Printer Preferences , follow these steps:
  1. Open the Control Panel .
  2. Open Printers and Faxes .
  3. Right-click HP Color LaserJet CM2320 MFP Series PCL 6 , and select Printing Preferences .
  4. Under the Advanced tab, change the Print Data Optimization from Auto to Optimize for Text and Vector .
  5. Now try printing the document.
  6. If the document did not print then try turning the printer off then back on. Try printing the document again.
Rameshkumar . R
[email protected]
PCL XL error problem
Try to update the latest firmware for your printer.
PCL XL error when i give command to the printer from my pc, i get the following error PCL XL error Subsystem: KERNEL Error: IllegalTag Operator: Oxlb Postion: 6
I already answered this, but the response did not get posted.
The short answer is that the PCL XL interpreter has picked up the use of the "Escape Code" (0x1B) in the incoming datastream. This command is used for the standard versions of PCL, most notable PCL 5e. It is not used in the PCL XL datastream.
Don
1helpful
I have an HP Color LaserJet 3800 printer. I am trying to print a document and it keeps printing: PCL XL error Subsystem: GEDI Error: MemA L LocError Operator: ReadImage Position: 743
That means that the printer does not have sufficient memory tp [rint the document, if it is a text document (eg word) try to print pages in groups, if it is a different document try the following:
" I receive a 'PCL XL error' on my HP 4100mfp when making a 2 page copy as one page in duplex? Why?
The problem is related to a printer memory problem.
If following parameters are set in the HP 4100mfp you will receive and 'Insufficient Memory" error.
1) In 'COPYING' the 'IMAGE QUALITY' is set to 'BEST'
2) In 'ORIGINALS' the 'CONTENT' is set to 'PHOTO'
Following error message is printed:
PCL XL error
Subsystem: GEDI
Error: InsufficientMemory
Operator: EndSession
Position: 32
The solution is to set 'CONTENT' to 'MIXED' or 'TEXT' or set 'IMAGE QUALITY' to 'NORMAL' or you can add additional memory to the HP 4100mfp. "
from euroform.com - FAQ
4helpful
2answers
Pcl xl error warning: Illegal media source
Some people have issues with the PCL6 driver this causes pcl xl error like this to print. Change your driver from the PCL6 driver to the PCL5 driver. If you don't have the software you can down load it from HP at: http://welcome.hp.com/country/us/en/support.html
Thanks...V
2answers
PCL XL error
It is a driver error, try another printer driver version or use PCL 5 rather then PCL 6 driver,
Check your USB cable it must be HighSpeed or USB 2 cable.
3helpful
PCL XL ERROR INSUFFICIENT MEMORY
you can try to use the HP 5L driver instead of the canon driver, I suspect you get this error when printing PDF files
k24674
Grand Canyon Tech
Grand Canyon Tech
