Service or admin?????????????????????/
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Konica Bizhub Password Reset
Konica Bizhub c350 default password is 12345678 give that a try
SOURCE: how do you reset the life of the transfer unit on the Bizhub C250
Yes,
Remove Trasfert belt unit.
On the left handled remove one screw ( spring fixer) and remove right srew (over the belt / bar whit finger fixee).
Remove, on the left spring stoppage and metal handled.
Remove black little srew and take to hand fuse contact.
Change fuse (behind) with new identical fuse and reassembly.
It may be reset trasfert belt counter.
Sorry for my not good english.
Bye.
SOURCE: when I turn on the machine (bizhub c300) error
This is a fuser related code.
To reset the code, please do the following
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch Trouble Reset.
4. Check to make sure that OK is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after
and check if the machine starts correctly.
Good luck
