My electrolux EWF1087 has power (power light and door light is on) but the LED screen is blank with no other lights on consol. Machine will not start. Looks like it may have started when I turned it on as towels are a bit wet. I did try a manual reset (hold start and reset button at same time while turning machine on) but this did not work. Any advice?
See advice here:
https://www.fixed4free.com/answers.php?id=110786
SOURCE: Electrolux front loader wouldn't stop filling.
change water valve sounds like its stuck open ... if not only other thing it could be is your main pcb control board ££££££
SOURCE: My 7.5kg Electrolux Washing Machine whent bang and
your door lock has blown/short circuit turn power of disconnect plug take top of machine look down inside machine toward door lock and you shoud see the catch push hard with your finger and door will open be careful as there are some sharp edges in there.
SOURCE: Electrolux EWF1087. door locked shut. when i reset
sounds like door lock is faulty e42 is saying door is still open. could be wiring to door lock also.
SOURCE: My Electrolux ewf1090 front loader door wont open
Turn the power off and leave for 5-10 minutes then turn on. This should release the door lock the problem could be the pump drain filter is blocked clean this and it should resolve future problems.
SOURCE: electrolux ewf 1090, have an electrolux ewf1090
ewf1090 washing machine not working?
error E50 is displayed?
but no reference in manual that helps.
