Sorry this comes late, but we just went through this problem with our unit, but I hope this helps someone else out there.
We had the same problem. To fix this, you need to do a few things and hopefully it will work for you.
First, do you have the PIN that came standard on the phone? The standard PIN for these phones is 1234. Go to the advanced settings, and then REGISTER, and put the PIN in and allow it to go through the "registering..." mode. It even may beep and say "unregistered" but don't give up hope, If this happens, unplug the unit from your outlet and wait a few minutes, plug back in, and place the handset on the base. It should then work.
Normally , one base can register 4 hanset in EEPROM setting. The model, Maybe you can try press the "page" key, then plug the power cord , after 5 to 6 second , release "page" key. Try to register handset again.
Unplug base unit Remove both batteries from the phone(s) wait 60 seconds Plug in base unit Replace batteries in phone(s) Press speaker icon on base usnit for 5 seconds Press menu Select adv adv settings Select registration Enter 0000 then press ok should go from waiting, to searching, then to 'welcome' press ok... should be up an running!! :-)
I have just bought a Philips CD240 cordless phone in spain, but the instructions afe not in english. Could you e-mail the manual in english to [email protected] thank you so much
