Just want to find a way to save files, was told that hard drive not communicating,have tried usb recovery and disc drive recovery, no help, willing to try out-of-the-box solutions. looks like it may be total loss anyway. computer turns on,icon spins, restarts, preparing automatic repair and stops at Recovery blue screen, error code 0xc0000185 then shuts off.
SOURCE: Toshiba satellite pro l40 boot up problem
If you run a repair with the recovery disc you won't lose any info. The only time you'll lose the info is if you run a complete reload. Run the system disc until it gets to the point of finding installed operating systems, at this point instead of deleting the partition, press R and it will reinstall the operating system files only leaving other installed files and programs intact. Keep in mind that many times when this happens, it's a hard drive failure. If it is a hard drive failure, then you will have to replace the hard drive and you will lose the info, sorry.
SOURCE: Recovery Disc will not work
That's terrible. The right soution should be to try Ashampoo Uninstaller or similar software that gets off EVERY BIT of unwanted software. Use function "Install new applications". It asks for setup.exe, install.exe or similar executable file, that runs Antivirus 360 installer. Point to it. After all the installations completes, "Ashampoo Uninstaller" logs the installation. Now uninstall the unwanted program using "Uninstall logged programs". That's it!
If you really damaged your operating system, do buckup of your important data and reinstall OS
SOURCE: windows vista wont start
Ok,Try safe mode with command prompt,If you can get to the command prompt
Type these in one at a time and press enter ( let each one completely finish before typing the next one.)
Bootsect.exe /NT60 c:
Bootrec.exe /FixMbr
Bootrec.exe /FixBoot
Bootrec.exe /ScanOs
Bootrec.exe /RebuildBcd
bcdedit.exe /import C:\Boot\BCDBackup
SOURCE: I have a Toshiba Satellite L355-S7811 laptop that
See let me talk with you from experience...
The only thing that can be done is system restore to factory default and remember to backup your documents.
This is the only way to resolve the problem you are going through.
Cheers.
SOURCE: I have a satalite 300
try using ActiveBoot suite v5.0.5, when turnig on your computer. This program will scan your computer and show u all the errors,missing files, wrong dll,...and repair them. It worked very well for me as I had a TROJAN virus on my Toshiba satellite 300 and couldn't even boot anymore.
After that try use the RegistryBooster tool witch solves every windows problems.
I hope this will help. Good luck :)
