SOURCE: my Lexmark is X6100 Series - Cartridge Error 50C consult user guide
Cartridge Error 50C
Your print cartridge has shorted.
1. Power off your All-in-One and unplug it.
2. Plug in your All-in-One again and turn it on.
3. Uninstall and then reinstall your cartridges.
4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
1. Power off your All-in-One.
2. Use both hands to lift up the scanner unit until the scanner support holds it open.
3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
4. Remove the color print cartridge.
5. Lower the scanner unit until it is completely closed.
6. If the error message reappears, replace the black print cartridge with a new print cartridge.
If it does not repeat steps 1-3 and then go to step 7.
7. Reinstall the color cartridge and remove the black print cartridge.
8. Lower the scanner unit until it is completely closed.
9. If the error message occurs again, replace the color cartridge.
10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
11. Lower the scanner unit until it is completely closed.
12. If you receive the error message again, replace both cartridges.
SOURCE: cartridge error error 50C consult user guide
Throw it in the garbage or recycle if you can. Buy other than a Lexmark is the best solution.
Buying new cartridges does nothing, except pads Lexmark's bottom line.
SOURCE: cartridge error 1203 consult see user guide on display panel
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad... I would request you to try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
SOURCE: Lexmark P6250 Printer error 1203 - Consult User Guide
It is a hardware printing problem . Try to clean contacts in printers in cartridge holder by alcogol and elastic rubber. it may become dirty an poor contact. after this you can try this:
Put some layers of the sticky tape on cartridge to improove force of contact.
SOURCE: Cartridge Error 50C consult user guide. I
Error messages; Error: "Cartridge Error 50C"; Cartridge error; Black cartridge missing; Color cartridge missing
Solution
Cartridge Error 50C
Cartridge Error
