Microwave Ovens Logo
A
Anonymous Posted on Aug 24, 2017
No power to my Frigidaire Gallery Edition Microwave model # FGMV205KBA just stopped
Frigidaire Gallery Edition Model #FGMV205KBA hubby went to turn on, and it started, then just STOPPED. NO noise, no sound, no clock, no power. But we could smell a slight electrical smell. Unplugged the unit, checked the circuit breaker. Everything was fine at our breaker. Then plugged the unit back in. Still no power to the unit. This unit is just about a year and a half old.
richie46
Level 3:
Top Expert:
  • Microwave Ovens Master 12,962 Answers
  • Posted on Aug 24, 2017
richie46
Level 3:
Top Expert:
Answers
12962
Questions
Helped
2945491
Points
58151
Check internal fuse? Is the front door switch working?
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Dec 14, 2006
SOURCE: Cannot heat
Sounds like it overheated, tripped the thermostat, then the thermostat reset. Chances are you have a bad magnetron. GE may have a campaign (not a "recall", mind you!) to offer free replacements if yours is a model that has a known history of problems with the magnetrons. I would call GE and ask them about that. *grin* GE Answer Center 1-800-626-2005 24 hours a day, 365 days a year
Anonymous
  • 17 Answers
  • Posted on May 17, 2008
SOURCE: GEJE2160 Stop Working
It probably blew the main power fuse in side the oven. This may have happen because of a failure in the microwave or a line voltage surge or what ever. Repalce the fuse and see if it work. be sure to unplug it before doing this, If this does not fix it then you have a failure in the oven some were.
good luck
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Dec 13, 2008
SOURCE: LG Microwave LMVM2055ST Just stopped working!
We have the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If the cavity thermostat needs to be checked or replaced you'll need to pull the oven from the wall.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
To order Goldstar / L.G. parts, visit Vance Baldwin Electronics. You'll probably have to call them.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Dec 28, 2008
SOURCE: Frigidaire Gallery Microwave doesn't heat
With the symptoms you have, I would most strongly suspect a failed high voltage transformer, which is an expensive fix.
It may also be a shorted high voltage rectifier diode (which costs less) or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/xformer.html
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/cap_test.html
You can download Frigidaire / Whirlpool owner's manuals and installation instructions here.
They make removing the oven from the wall for service (or replacement) much easier.
Anonymous
  • 2992 Answers
  • Posted on May 28, 2009
SOURCE: microwave power shut off and stopped working
You can test safety thermostats with an ohmmeter. There should be a short circuit between the device's two terminals if it's closed. (This doesn't necessarily mean the device is good, though. It might be opening at too low a temperature when the oven is operating.) A high resistance or an open circuit means the thermostat has opened and needs to be replaced. An appliance parts store should have suitable replacements, or you can order from a number of online vendors. I usually start at the Sears parts site. They have part information for many models, and usually pretty fair prices for parts. But once you have the part number you need, a Google search will let you shop around.
It does sound like your oven shut down because of a thermostat. One is normally mounted on the magnetron tube that supplies the microwaves, and another is on the cooking cavity. I've had to replace these many times. If the main power fuse blows the oven will not come back on until it's replaced. But you might also have bad solder connections causing the trouble as well. I've seen solder joints on the control board and power filter board cause dead ovens.
If you're not absolutely sure of what you're doing working on a microwave, you might want to let a professional check it over and make an estimate. There are potentially lethal voltages present, and microwave leakage may be a concern as well.
Frigidaire Gallery microwave. The internal light stays on and internal fan stays on when the door is closed.
Try cutting the power to it for 15 minutes to effect a power reset to the mainboard.
It is still does it, you need a service call or a new one. It is a known issue.
https://www.google.com/search?q=Frigidaire+Gallery+microwave.+The+internal+light+and+internal+fan+stays+on
How do you turn the turntable on a frigidare microwave model fgmv155ctf on and off
Image Disclaimer
AUTHORIZED DEALER Frigidaire Gallery Series
FGMV155CTF
30 Inch Over the Range Microwave Convection Option Sensor Cooking SpaceWise® Rack
4.4 Average rating of
73 reviews
color: smudge proof stainless steel
Smudge Proof Black Stainless Steel FGMV155CTD
$569.00
Smudge Proof Stainless Steel FGMV155CTF
$519.00
product highlights
Optional Built-In Trim Kit Convection Sensor Cook quick specs
Dimensions
Width: 29 7/8 Inch
Depth: 15 7/16 Inch
Height: 16 13/32 Inch
Features
Capacity: 1.5 Cu. Ft.
Cooking Watts: 900
View more Frigidaire 4 Piece Kitchen Appliances Package
Get the bundle for just $3,44800View the Bundle Recommended Accessories Available Colors/Finishes Stainless Steel (FGMV155CTF) Black Stainless (FGMV155CTD)
Frigidaire GALLERY™ 1.5 Cu. Ft. 900W Over-the-Range Convection Microwave
Save
Model No: FGMV155CTF
Features:
  • 170/300 CFM 2-Speed Exhaust Fan
  • Convection Option & Sensor Cooking
  • Express-Select™ Controls
  • SpaceWise™ Convection Rack
  • Effortless Clean™ Interior
Frigidaire microwave
Check fuse inside microwave oven (usually 8-10-12 A) on power supply board or main board, depending on model.
Dado
My frigidaire Gallery microwave model #FGMV174KFA will intermittently lose power completely. After a while, it will beep and come back on, giving a message "enjoy your oven." Right now I'm not enjoying...
There could be a connection problem in the electrical outlet the microwave is plugged into or anywhere in that circuit all the way back to your electric breaker panel. It sounds like the microwave is losing power and resetting. WARNING: Any type of electrical work should only be completed by persons qualified to do so.
4helpful
Frigidaire microwave gallery series turntable is not turning
This co. has one for $19.99
http://microwaveglasstrays.com/shop/microwave-turntable-motor-st16fe-ex73saaa3-p-214.html
I am also looking elsewhere
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
