Cars & Trucks Logo
A
Anonymous Posted on Mar 21, 2017
Mark II Grande cylinder head noise
The car when at starting rave of 1.5 rpm makes a rattling noise like dry bearing. When you r going up a steep road, the rattling increases. On neutral there is no noise. After much investigation, we found the noise coming from the Cylinder head. So i did a full service changed all the plugs, changed oil & filter, gearbox oil, there was leakage on timing belt seal so we changed that. But the noise didn't disappear. Instead now there is a check engine light on. When we ran diagnostic on it, it states VVTI sensor error, camshaft. Now I am not able to buy the complete cyclinder head, but there is no heating, or any issues, except the noise. Where could this noise be coming from the cylinder head? What mechanics cause a rattling inside the cylinder head.
Marvin
Level 3:
Top Expert:
  • Cars & Trucks Master 85,242 Answers
  • Posted on Mar 21, 2017
Marvin
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29024156
Points
266281
Sounds like a bad rod bearing, no cure except a rebuild. I assume you do know the difference between spark knock and bearing knock.
5 Related Answers
Anonymous
  • 1263 Answers
  • Posted on Sep 25, 2008
SOURCE: 2007 Escape oil pressure issue/oil pump
one thing to keep in mind that even though the vehicle is new you can still have major engine issues, because of the bearing material may have been bad at production.taking this in account any part on a vehicle can fail prematurely either because of poor insatllation or improper manufacturing. As far as oil filters are concerned bthe odds of mechanic installing the wrong filter are slim to none.the oil pressure sending unit only senses that here is oil flowing through it. it doesn't set the light off unless there is absolutely no pressure at all the only way to see the pressure is to have a gauge. oil prssure should be abot 45 psi at 2000 rpms. the only way a filter would effect oil pressure is if it was completely clogged. It would take a great deal of coolant in the oil to ruin a set of bearings and before that happens your vehicle would not run very well and you would notice a great amount of white smoke out the exaust. this would indicated either a blown head gasket.cracked head or a cracked block. you never mentioned what they found in the anaylasis of the oil. I presume that your vehicle is still under warrenty on the powertrain. I would suggest that you have the dealership check your oil pump out. every vehicle will have a small amount of metalic residue in the oil. large shavings and chunks of metal would be a worry. please rate this thanks.
Anonymous
  • 30 Answers
  • Posted on Dec 15, 2008
SOURCE: 2005 Nissan Sentra 1.8s...SES light on. PLEASE HELP!
well if the head gasket has been replaced you shouldnt smeel any coolant. But have you check your coolant hoses???? for leaks or any coolant on the driveway, when your car has been sitting there overnight!???
Anonymous
  • 99 Answers
  • Posted on Dec 26, 2008
SOURCE: Check engine light comes on. p0171 and p0351 codes found
From Lusty Kid:
I know the economy is bad, but change all of the plugs. Check your PCV Valve hose, 150 rottens them out allowing air to be sucked in, thus all kinds of codes.
Depending on mileage. Dismount the EGR valve and clean passages. If you are really good dismount the throtle position sensor body and clean out passages with Choke Cleaner., dismount where the EGR valves connects to the engine, clean out passages. Also check the hose thats behind this mounting to ensure is not clogged. If clogged clean it out. If not replace it. Is about 1.5 ft. long, connects to the PCV Valve Hose.
When is the last time you change your harness. Can't remember??? Replace it. Good Luck
Anonymous
  • 315 Answers
  • Posted on Mar 05, 2009
SOURCE: 1996 Jeep GC - Diagnostic tool identified cylinder misfire
P0300 Code - Random Misfire
Symptoms Symptoms may include:
  • the engine may be harder to start
  • the engine may stumble / stumble, and/or hesitate
  • other symptoms may also be present
Causes A code P0300 may mean that one or more of the following has happened:
  • Faulty spark plugs or wires
  • Faulty coil (pack)
  • Faulty oxygen sensor(s)
  • Faulty fuel injector(s)
  • Burned exhaust valve
  • Faulty catalytic converter(s)
  • Stuck/blocked EGR valve / passages
  • Faulty camshaft position sensor
  • Defective computer
juggernautxt
juggernautxt
  • 145 Answers
  • Posted on Apr 30, 2009
SOURCE: 2001 daewoo lanos check engine light
oil is non conductive so I doubt that's the problem, but the oil leak should be fixed to reduce problems down the road.
as for the misfire could be a couple things, fouled plug(s), a plug wire(s) that has cracks, or even valves that are not seating which i doubt from your explanation.
I would change your plugs and wires first, and fix oil leak. if this does not fix the issue there are other things going on.
1helpful
Hi my engine make noise when i accelerate and stop when hidling its fordbantam 1.3 2007 rocam
It’s difficult to say because engines make a wide variety of noises.
Rattling, possibly a worn timing chain.
Misfiring, possibly incorrect valve timing or damaged head gasket.
Metallic scraping, possibly a lack of oil pressure causing bearing to run dry.
Knocking, possibly worn mains or big end bearings.
Loud exhaust noise, possibly a blown exhaust manifold gasket.
There are a wide variety of possible noises and therefore a wide variety of possible causes
Victor 930 2
Sounds like you have problems with the turbo as thee is a bearing there and you said it starts rattling once the turbo kicks in. There is one other thing, you may have internal engine damage as like you said, only 500 miles and some of that was racing. May not have been broken in properly. I know I was told you need to break an engine in for 500 - 1000 miles then change the oil. I hope this is not the case for you though.
My car is making bearing like noise just like pink...but the noise is not constant. It only appears when the start of acceleration occurs between 1500-2000rpm. The noise is coming from the front of engine,...
Does your vehicle have a serpentine belt ( flat and wide, ribbed on the inside)? if so,first I would check the belt tensioner. You'll need a tensioner tool ( rentable from Autozone with a refundable deposit). Before starting, observe the routing of the belt, as this is crucial to your motor ! Release the tension on the belt and slide off of the tensioner. Holding the belt out of the way, spin the tensioner. listening for the popping or snapping sound. If the tensioner is ok, check the idler pulley the same way - I'm pretty sure it will be one of the two. Other than this, I would need more specifics of your vehicle in order to research. If the motor is not running hot, I would not suspect the water pump - which may or may not be operated by the serpentine belt.I would not run the motor until you determine the problem - most newer motors are interference motors, meaning the pistons cannot be in the up position while the valves are open, or else serious damage will occur to the valves ( typically the exhaust valves and guides are severely damaged).Also, if it is the tensioner or idle pulley, you could lose the belt while driving which would knock out your power steering, alternator, and possibly your water pump.
I hope this helps and thanks for using Fixya!!
Rattling noise
Check catalytic converter.Catalytic converter could be breaking up inside.
1helpful
2answers
It's like a rattling loud noise that comes out from the camshaft sprockets and timing belt on my 1998 dodge caravan 2.4 engine. it started while running on the road.
Could be the timing belt tensioner. They are known to make a rattling noise when worn and/or the belt has stretched....When is the last time you had the belt serviced? They should be replaced and pulleys inspected at 100,000 miles. Gates recommends 120,000 miles on their belts. Good luck, i hope this helps.
Hi i have a 96 excel x3 and at start up it rattles and under revs it rattles and have to find the right spot so it dont rattle wen im driven
It could have many problems. It could be bearing/piston noise. A head gasket blown cylinder to cylinder or many other problems. I would reccomend not driving it. Get a mechanic to listen too it. He should be able to tell you if its a major engine problem .
1helpful
Sounds like a bearing going bad where do i look first
a rod bearing makes noise when you are just barely pulling .. it likely will quiet down as you accelerate and decellerate .. you can rev the engine up a bit then let up on the gas just enough to keep that rpm ..a rod bearing will rattle a lot then ... if a thud like noise happens when you are accelerating . then it could be a main bearing .. if the noise is there all the time and sounds like a rattle then its more likely a valve problem .. old oil can cause the lifters to stick and rattle continuously .. if the noise you hear is a squeal then you could have a bad bearing in the idler pully (for fan belt) or alternator .. if thats the case you can put a drop of oil on the bearings one at a time until the squeal goes away .. that will identify which part is going bad .. there are other less likely bearings that can go bad .. like the cam, distributer, air compressor and water pump .. each have their own type noise ..
Toyota Cressida noise
Check Brake caliper and pads may need shims on pads, if its a rattling noise on bumpy roads calipers will rattle if brake clips or shims are missing. Car moving from left to right by itself could be a few things 1 Bad rack-and pinon mounting bushings 2. Bad inner or outer tie rods. 3. bad ball joints 4. uneven wear on tires. check all of the above and you will find your problem. Rpm guage not working more than likely is the cluster itself is going bad or malfunction. I wouldn't worry too much about since it just RPM.
Truck makes loud noise unless clutch is pushed in
chances are the adjustment of the throwout bearing fork is the problem . because of vibration that is the rattling that you are hearing. correct adjustment should be as follows.
#1...peddle travle should be no more than 1 1/2 inches
#2...the clearance between throw out bearing and fork no more than 1/2 inch
#3...clearance between fork and fork stops is 1/8 inch
also there should be grease zerts in the shaft that holds the fork and linkage make sure they are not dry of grease...please rate the solution....thanks
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
