Sunbeam 5891 Bread Maker Logo
A
Anonymous Posted on Feb 01, 2014
Bread machine beeps and lights blink as I plug it in, but doesn't light up or come on after fully plugged in
Went thru a complete dough cycle, Turned the machine off. Cleaned the bucket, then went to start another batch. Nothing, no beeps, no lights. Is there a reset?
This happened to me also. What worked for me was to unplug the machine and wait at least an hour, then plug back in. It may reset for you. Good luck
3helpful
My computer doesn't send signal
Whenyou plug in the power cord is there any lights whatsoever on the laptop, wherethe plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the computer is trying to boot or may have booted,but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe you have a Static ChargeBuildup. Remove the Power Cord, then Press and Hold the power button for30 seconds. After 30 seconds plug the power cord back in and hit thepower button to see if it boots. Maybeyour memory is bad or the memory slot is bad.Removethe Power Cord, Open the Case and remove one of the memory chips. Set thechip aside then try rebooting the computer. If it boots, then you knowthe memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and tryrebooting. If it fails take the chip out and set it aside, then put theother chip in and try booting it in both slots. If it boots, just toverify that the chip set aside is bad, mark an x on it and put it into the openmemory chip slot and try booting.
Battery light is blinking on the dash of my 1998 k1500 and the daytime running lights are flickering also
Check your AC Adapter plug. If it's damaged, you may be getting intermittent breaks in contact. If you're not sure if it's damaged or not, pull your battery and try to boot up with just the AC Adapter plugged in. If it doesn't shut off, it's probably a bad battery. If it does, you need to get another AC Adapter or have the plug on the machine replaced.
Put in all the ingredients and presssed the start button counting down but nothing is happening
More details would help troubleshooting. For example, are you sure the machine has power (is the LCD display working? Is the light above the on off push button on?). The circuit breaker for the outlet it's plugged into (it is plugged in fully, right?) may have tripped, for example.
It wont start gust does beep beep beep
Is there a light blinking on the back of the computer near the fan or plug? If so you need a new power supply unit.
My breadmaker has stopped working. I unplugged it when the 'alert' light came on, so I re-plugged it in and waited for the 'alert' light to go off. Then I unplugged it and came to re-plug it in later on...
This problem happened to me twice in the past two years. The situation arises when any bread-making cycle is interrupted by switching the power off. I was was thinking that the machine was finished. The solution is to wait long enough (24 hours or more) for the internal cycle to reset itself. Since I couldn't study this problem at leisure, I cannot tell if the power should be ON or OFF. Just turn on the machine to see if it's over.
Richard F.
3answers
How to remove bread from bread pan
This is model specific. Ask here for user manual for your model.
4helpful
2answers
Coffee maker beeping
Is your grinder in and the lid down? My coffee maker (grind & brew) started beeping after I cleaned it and turned the left knob clockwise with the grinder still disassembled. There's a little button that is depressed when you close the lid with the grinder in there (I'd guess it's a safety feature). I pressed down that button, and the beeping went away.
Top Sunbeam Kitchen Appliances - Others Experts
Mike Cairns
Mike Cairns
Thomas Perkins
Thomas Perkins
Are you a Sunbeam Kitchen Appliances - Other Expert? Answer questions, earn points and help others
