My laptop says "windows has not shut down properly" and then gives three options:
-start with safe mode
-start with safe mode and networking
-start with safe mode and command prompts
I've tried all three but it still doesn't work. It says "welcome" on the windows screen but then goes black and I have to turn it off.
What else can I try to get it to start up properly?
Which OS do you have? Have you tried booting to safe mode?. Restart the computer. Immediately after the BIOS post ends, start tapping the F8 key repeatedly. when Windows Advanced Options menu appears, select safe mode and see whether it boots completely without blue screen(BSOD)
Hello there, i just owned a brand new Asus T100 for 2 days and today on the 3rd day after purchasing, i faced problems during boot/start up where the laptop gets frozen on the Asus logo screen.
I tried holding down the power button for 10 seconds and turned it on again. It ran a series of windows software updates before the start up, then after all software updates have been completed, the laptop resumed to freeze at the Asus logo screen again. I tried holding the power button for 10 secs followed by holding the power button and volume up button at the same time, to get into automatic repair/repair mode. THIS HELPS, get into the repair mode!
To cut it short, i tried the other advanced options as well as the restart button in the repair mode but to no avail. After carefully reading the different options in the 'advanced options' in repair mode... Here's what worked for me:
1) If you're stuck at the Asus logo screen which doesn't seem to boot for ages or at least 10 minutes, hold down the power button for 10 seconds and let the screen turn black. (I did this with my charger plugged in, not too sure if it matters)
2) Count to 10 seconds. Switch the laptop on by HOLDING THE POWER BUTTON + VOLUME UP BUTTON at the same time. This will send the laptop into an 'automatic repair', followed by a 'diagnosing this PC' and after which you will see a blue screen which is the repair mode.
3) On the blue screen you will see 2 buttons, 'Restart' and 'Advanced Options'. Click on 'Advanced Options'. (DO NOT CLICK RESTART, it does nothing as you will get stuck again at the logo screen)
4) After clicking 'Advanced Options', click 'Advanced ....' (i forgot what exactly) and click 'STARTUP REPAIR'. This is the crucial part.Then follow whatever the system promts you.
5) Afterwards, it will attempt to repair your system then lead you back to the logo screen for startup.
6) Wait a few minutes and you should be able to get to your login screen as usual.
Hope this helps. I chanced upon it by guessing which would actually help me.
Boot it up in safe mode, then shut it down (start menu, shut down), and start it back up again.. if it still give you that screen then it could mean when you dropped it a piece of hardware (like the wi-fi- card) came loose. You could then pop open (assuming you have no warranty on it) and just pull parts out one by one and re-seating them.
try booting into Safe mode, as the computer is booting press and hold your
"F8 Key" which should bring up the "Windows Advanced Options Menu" as
shown below. Use your arrow keys
to move to "Safe Mode" and press your Enter key.
Note:
With some computers, if you press and hold a key as the computer is
booting you will get a stuck key message. If this occurs, instead of
pressing and holding the "F8 key", tap the "F8 key" continuously until
you get the startup menu.
*You can only use this solution if your Administrator account has no password.*
Boot your laptop to safe mode by following these instructions.
* If the computer is running, shut down Windows, and then turn off the power
* Wait 30 seconds, and then turn the computer on.
* Start tapping the F8 key. The Windows Advanced Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again.
* Ensure that the Safe mode option is selected.
* Press Enter. The computer then begins to start in Safe mode.
After all the necessary drivers and system files have been loaded you will be presented by the Log On screen click on "Administrator" icon and wait for your computer to finish booting. Then click on Control Panel. Under Pick a category, click User Accounts. Under Pick a task, click Change an account. Under or pick an account to change, click the account for which you want to access here you will have to remove it's password. From here click on Remove password, it shouldn't ask for any verifications from here. Click on Ok or next then exit control panel and restart your computer.
If you are still unable to access your account try following the solutions on this link.
If you have run the laptop in safe mode it uses the standard VGA graphics driver, and this indicates the onboard graphics card is still functioning. Try connecting and external monitor to your laptop and the boot up your laptop. Then :- 1. Download the latest graphics driver from ASUS WEB site. 2. uninstall the graphics driver. 3. Reboot the laptop and install the new graphics driver. 4. Shut down and remove the external monitor and reboot. 5. Goto the Control panel - Display and check/set the settings for screen resolution, Colour setting etc.
If you have a Windows XP or Windows Vista CD (or if you can borrow one), insert it into the CD Drive and restart the system. Boot from the CD, and choose the "R" for Repair console.
Log onto the Windows installation you want to repair.
The driver irql_not_less_or_equal error can have multiple causes, but most of the time it is a hardware/driver issue. Check if there are any new drivers available for you computer's hardware devices and update them if so. Running a memory test also does not harm, could be faulty RAM.
Greetings,
If we had a clarity on the OS you are using it would have been easy. Do not try to change the mode. Shut down the comp and then try to restart, as it starts then tap the F8 key on the keyboard. We'll get the option for Safe mode. If still you do not get through.
Not being sure why you want to goto safe mode you can always use a plug an play external CD ROM. In case the issue is not resolved for safe mode you'll need to repair the Windows.
