Question about Iomega HDD External Desktop (32660) 80 GB Hard Drive
Iomega external drive does not power up, light blinking
Hd won't power up
Anonymous
SOURCE:
antiochpc
Kevin Shafer
  • 1314 Answers
SOURCE: No Power to External Hard Drive
Do you have access to a multimeter or voltmeter? If you do you can check the voltage coming out of the adapter and make sure it matches what the power adapter says it is. If it doesn't, then it is the power adapter. If it does, then it is the drive or enclosure.
Posted on Jun 21, 2007
Anonymous
  • 135 Answers
SOURCE: my iomega hard drive is dead how can I fix this?
Disconnect any leads and remove the outer cover.
Check the hard disk inside is securely pushed into the receiving socket.
Replace outer cover and give it a try.
Sometimes a knock can dislodge the drive and cause the problems you describe.
Best wishes.
Posted on Mar 03, 2009
Anonymous
  • 57 Answers
SOURCE: iomega external not visible
Unfortunately, Windows isn't the most efficient operating system when it comes to it's "Plug 'n Play" abilities. In my experience, external hard drives can be particularly sensitive when it comes to unplugging the data cable while navigating the drive. I've had two external drives lose all data because of that flaw in the NTFS file system. The MFT exists on every drive with NTFS storage method. If that becomes corrupt, it can render the drive useless.
The drive may have power, but that quiet beeping you hear is an indication that the reader head is stuck to the platter and may be grinding into it. There is a myth (may or may not be true) that says if you put the drive in your freezer for a few minutes, take it out, drop it from 6 inches onto a hard surface, it may knock the head loose and make the drive work again.
I tried that method, and it made the situation worse for me, but it may work for you. I would resort to that option only if nothing else fixes it.
Posted on Aug 09, 2009
Mark Gergel
  • 29 Answers
SOURCE: Iomega large external hard drive doesn't show up
Well this is a tough one. I am assumeing that you have done all the normal things.
Most external hard drives are just a standard internal hard drive with a case and a IDE/SATA to USB adapter built in. When you plug in the drive and it powers up listen to the drive if you hear a clunk. Not a the happy ticking of a normal drive but a bad clunk. This can mean that the controller on the hard drive itself is bad.
If everything sounds happy then I would try replacing your power adapter. I know that the blue light goes on but most of that runs off the 5 volt leg of the power supply (I have has some hardware manufacturers actually pull the power light voltage from the USB port Grrr) most of the Large sized external hard drives use a 12 volt adapter and it can have no problem with the step down to 5 volt it may have a problem with the 12v.The 12v is what it uses to spin the drive. Unless you have one of those little drives. They use a laptop hard drive that works of a lower voltage. Most of the time you can get an adapter from Radio Shack. Be sure to bring the old one so they can get the Volts, amps, poleartity and the type of connector. It is worth a try and keep the reciept. If it is just bad I am sorry but the only way to get the data off is to break into the unit and pull the hard drive out. Then use another USB to IDE/SATA adapter to pull the data off.
Hope this helps a little.
Posted on Sep 13, 2009
hamster47
  • 739 Answers
SOURCE: cannot copy files to Iomega 500 GB external hard drive.
It depends on how you formatted the the drive.
If it was formatted FAT it will work on both Mac and PC.
If you formatted to HFS+ (the native mac format) then it will only work on a mac.
Posted on Sep 17, 2009
Blinking light on iomega external hard drive
Try plugging the unit into another working computer. If the same thing happens then the external drive is toast. U may be able to remove the drive with within the unit, set it up as a slave, install on working computer and possibly extract any and all needed files before throwing it out.
Nov 22, 2013 | Iomega Prestige 1 TB USB 20 Hard Drive
Iomega floppy usb-powered external floppy drive on windows 8
Hi, Sounds like driver related problem to me. Try use this tool to update the drivers: Driver Update Software for XP Vista 7 8. Wish you best of luck.
Nov 30, 2012 | Iomega Floppy USB-Powered External Floppy...
My 500gb iomega external hd model : MDHD-UP . is not working i think its the power supply that has a problem because my friend use the wrong adapter instead of the right one 12v he use my laptop's
Hi sir/madam
Use only 12v adapter for your drive...purchase same volt adapter...
Still not working remove the casing of iomega , connect it as internal drive on desktop ..
If it is under warranty pls go for service centre
Sep 21, 2017 | Computers & Internet
I CANNOT LOG ON TO MY 500GB IOMEGA EXTERNAL HARD DRIVE
can you see the External HD on the My Computer? and when you right click to open or double click won't open? but if you can open the external HD using the drop down tool at the my computer, then the problem is virus. You should update your anti-virus then scan it to delete those virus, and if you do not have any important files, i guess its much better to reformat the drive.
please let me know your further query.
regards,
toeped
Aug 24, 2011 | Computers & Internet
My iomega drive just keeps blinking and my computer can't access it. I have two drives to store my music and I'm not sure if it was the power source or my laptop but both stopped working and all I have is...
Dear tmetal,
Hard drive anda memiliki external power source atau hanya menggunakan USB cable ?
I think it's a problem power source, power from the notebook is weakening, therefore it is not enough voltage to your hard drive.
To make sure, try connect your Hard Drive to other computer.
regards,
dm
Feb 15, 2010 | Iomega Computers & Internet
Iomega Minimax HD, no power but lead light is on. Working fine, then I turned it on today & nothing, no fan, no light but the power lead green light comes on. How do I know if its the HD or the power lead...
In your situation I would :
open the minimax enclosure, and take the hd out, (just open the enclosure, not the hd itself), and then open your desktop and connect this hd as slave (I am guessing you have a desktop with IDE hd and that the minimax has an IDE hard drive in it.... or both your desktop and the minimax has SATA hard drives) and then when you turn on your computer you should be able to see your second hd as a partition and be able to see the info in there, yet if windows does not recognize it, that means your hd is useless., yet remember you have to change the pin on your external hd to be slave or auto detect, if you let it as master your computer won't boot, bout do not worry, after you unpluges the hd from your desktop everything will be normal
p.d.
shutdown and unpluged the power cord from your desktop when adding/removing the hd.
Apr 18, 2009 | Iomega MiniMax Desktop - Hard drive - 500...
Iomega mini max external HD slowing things down
the hd external iomega 500 gb minimax have a litle noice and don't work dont conect whit my computer.
Mar 06, 2009 | Iomega MiniMax Desktop - Hard drive - 500...
Iomega lphd160-u beeping
Your USB port does not have enough power to support the drive. You will need to use an external power source or try a firewire cable if the drive has that option.Travis Cable
Mar 29, 2008 | Iomega (33600) 160 GB USB 2.0 Hard Drive
Iomega HDD External Desktop (32660) 80 GB Hard Drive Logo
304 people viewed this question
Top Iomega Computers & Internet Experts
GreatAbyss
Ekse
ChinthakaJ
ChinthakaJ
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
