EVERYTHING SEEMS TO BE WORKING EXCEPT THAT THE KNEADING DOES NOT TAKE PLACE
SOURCE: breadmaker has steam inside window on top
Check the back of your machine and make sure that the steam outlet just below the lid hinge is cleaned out after EVERY USE, this can be clogged up or even moldy if not properly cared for. Soak in mild bleach water if clogged/moldy, rinse in hot water after every use
SOURCE: INEED TO DOWN LOAD MANUAL FOR A SUNBEAM BREADMAKER
Find that here for direct download:
http://manualfox.com/link/sunbeam.htm
SOURCE: Sunbeam 5891 Breadmaker stops for several seconds
It is normal. It allows the dough to fall back on the mixer blade. Often these reverse and that also gives the motor time to come to complete stop before reversing.
SOURCE: Sunbeam Breadmaker Pan
You can call 800-528-7713. I just ordered and pan and blade for $ 31.18, including shipping. They have a website: www.jardenstore.com. I just went to the site, and couldn't find the pan, so I would recommend calling the number.
SOURCE: how to get kneading blade
These are a pretty common blade. I'm pretty sure you can find one on ebay? If you don't ebay let me know and I will try to find another source.
