Oreck XL2000 Bagged Upright Vacuum Logo
Posted on Jun 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Oreck Vacuum cleaner keeps burning up belts. I
My Oreck Vacuum cleaner keeps burning up belts. I have cleaned the bar very well when I replaced the belt. When I spin the bar with my finger before the belt is attached is still has some resistance. Is there a lubracation that I should use? the bar is wooden the the part it spins against is plastic.
The vacuum is actually an oreck xl extended life model xl9000w. The site would not let me post unless I picked a model from its list.
Thanks
Joel C.
Level 2:
New Friend:
  • Expert 42 Answers
  • Posted on Apr 28, 2014
Joel C.
Expert
Level 2:
New Friend:
Answers
42
Questions
0
Helped
11860
Points
142
Ours is doing the same, burning smell and chewed up belts. Not happy customer.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 05, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
2559
Points
I am having the same trouble. I bought the vacuum new in October 2007 when my wife and I purchased a newly constructed home. Since it is only two of us, she only has to vacuum once a month. I have taken it in three different times and get the same story. It needed a new belt. Mine has white smoke coming out of it and smells like burning rubber. I contacted Oreck and got no results. They refused to let me discuss this with Dave Oreck, stating that he nevers talks with customers! Gary Neeble
Oreck vacuum cleaner stop and burn smell
sounds like hair or string or something like that is wrapped around the beater bar(the long brush under the head that brushes the carpet) keeping it from turning. The belt that drives the bar is getting hot because the beater bar is stuck.
2answers
Oreck xl won't start
This could be for various reasons. Check the power cord and try a different outlet first. See if the power cord is loose or damaged. Next check the brushroll and belt that those are in working order. If you smelt burning or electrical fire or your vacuum made an odd noise before stopping it may be the motor going bad. If your power cord is good and the brushroll and belt good, it is probably your motor going bad.
Replacement Oreck Vacuum Cleaner Motor
GoodVac
800-775-6586
2answers
Oreck vacuum is smoking and the roller is not turning. vacuum is turning on and inflating well.
Sounds like the roller is jammed up. The motor keeps driving the belt, but for some reason the belt cant drive the roller. The smoke is coming from the belt, Clean the junk out from the roller.
1helpful
Oreck Belts
Unfortunately this is a very common problem on the Oreck XL uprights. As you you noticed, there is even an extra belt storage on the machine itself, on the bottom plate. When a vacuum cleaner has to put an extra belt on the machine, this should be a clear warning sign that you're going to have replace belts.....frequently! Unfortunately this is just the nature of the beast. Since there is no height adjustment on the nozzle itself, the vacuum will lower until it hits the carpet, the carpet is the only thing that adjusts the height of the carpet attachment. On other vacuums you have the ability to raise and lower the brush head according to what type of carpet your cleaning. When the brushes are at the proper height, the belt is also running at the proper tension and strength on the brush. Since the Oreck doesn't have a height adjustment, the brushes have a lot more resistance to the carpeting, which is what leads me assume that's why the machine goes through so many belts.
Oreck XL's were designed for hotels. Their slogan used to be "The Hotel Vacuum for you Home" even. Anyone who has ever stayed at a hotel knows that most have a very low pile commercial grade carpeting. The Oreck XL does a fabulous job at cleaning low pile carpeting that doesn't have a lot of dirt to vacuum up (restaurants kill most vacuums, but especially Oreck). The problem is that the Oreck XL was originally designed for cleaning low pile commercial grade carpeting, and not to clean plush, piled carpeting. The Oreck's have a 4 AMP motor in them, and where as it's true AMP's don't equal suction power, it's safe to assume that a 4 AMP motor will not produce near the suction as a 12 AMP would. When cleaning low piled commercial carpeting, you don't need much suction power, even an electric broom can clean this type of carpeting.
Oreck however does do one thing right, and that's advertising. David Oreck is everywhere! Newspapers, TV commercials, internet advertising, direct mailers, and more. They spend so much money advertising their vacuum cleaners that everyone is familiar with their products. What most people don't realize is that the customer is the one gets to pay for all of the advertising that's being done! Through the power of advertising, Oreck has taken what should sell for a $100 electric broom, and turned it into a $600 full size upright! Dyson vacuums are the exact same way, a lot of advertising, but not much vacuum behind the price.
Chances are that if you heard about a product through a info-mercial, or a newspaper add, then that product automatically is going to be sell for more then it's worth.
Unfortunately I can't help you fix the problem with your Oreck continuing to burn belts, but I can give you a link to the belts on our site if you need to purchase them. We offer free shipping:
3 Oreck XL® Upright Vacuum Replacement Belts
If you (or your friend) would like a personalized recommendation of a good vacuum specific for your exact cleaning needs, please feel free to add a comment, or contact me, I'd be happy to help.
Chris J.
GoVacuum.com
I am not sure how o install a new belt on my oreck vacumm, can't
here is the insturctions (copy and paste in your address bar)
http://www.oreck.com/vacuum-cleaner-bags-and-belts/index.cfm?keycode=DB475
I put a new belt on my oreck xl and it is burning through why?
The problem you are having is that the brush roller is not spinning freely when the belt is not on. if the end caps of the roller can be removed, clean the dirt & carpet fiber out and test. if it can not you just may need to replace the roller
Iā€™m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
19helpful
13answers
Oreck Vacuum Cleaner problem (upright)
The best solution to any Oreck vacuum problem is to replace it with another brand. You are going to continue having problems with the Oreck..Not that other brands don't have problems. But, at least with
other brands the problems don't occur as often. Belt burning up. clogs, roller brush bristle wearing down prematurely, cord breaking internally, etc.
P.S. Oreck is good at one thing. Marketing!
Belt burning
the beater bar probably needs to be removed & cleaned. the shaft & bearings get bound up with hair, string, etc.. with the belt off the bar, it should spin fairly easily. if it's hard to turn,(belt off) then it's bound up.
Top Oreck Vacuums Experts
john h
hsapiens
Level 1 Expert
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
