SOURCE: HOW CAN I GET AIM ON MY BLACKBERRY PEARL 8130
Good afternoon!
Depending on your cell phone provider, most Pearls will come with AIM. It is part of the applications they put on the phone. If you cannot find it, go to this link with your blackberry phone:
http://www.blackberry.com/aim
Then follow the on-screen instructions to complete the install.
Hope this helps!
SOURCE: 507 error
my computer/C:/program files/common files/Research In Motion/ AppLoader.... remove the Vendor file from the folder and reinstall the OS using Desktop Manager...
SOURCE: blackberry pearl
Try holding these keys simultaneoulsy.
ALT+RIGHT SHIFT(CAP)+DELETE Until you get a blank screen then power on.
Failing that power off, remove your battery for 30 seconds and then power on.
SOURCE: blackberry pearl 8130. screen wont come on.
To help you with this problem, I want you to know that when a cellphone
got fell, the main problem will be make is lost in display,you will not
see anything but you can hear something like message tone and start-up
tone, you can also receive calls. Don't be worry with that kind of
problem. To tell you whats happening inside your phone is your LCD of
display connection is only misaligned. Get it to the nearest cellphone
repair center to get your cellphone to be open by a technician and
probably they will do dismantling your phone and fix the problem. Hope
this could help. Don't forget to say thanks..:-)
