Computers & Internet Logo
M
Megan Kube Posted on Feb 02, 2014
STRANGE MESSAGE WHEN PVR TURNS ON
When I turn on the PVR I get a message that says "You are going to enter the hard disk format process. All data in this hard disk will be lost after this process. Please read the user manual to get more information". I can't access my recorded programs, but I can still watch TV through the PVR. Does anyone know what's going on? Why has this just started, apparently for no reason?
gavin hunt
Level 1:
New Friend:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Feb 02, 2014
gavin hunt
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
10
Questions
0
Helped
1418
Points
27
5 Related Answers
Anonymous
  • 91 Answers
  • Posted on Oct 10, 2007
SOURCE: hard disk is read only
format your hard disk with disk manager software. (low level for formating). this software can remove bad sector of your hard disk
Anonymous
  • 13 Answers
  • Posted on Aug 09, 2009
SOURCE: Corrupted and unreadable hard drive
Ifyour external hard drive hasn't suffered any physical damage, thendue to a power failure, improperly disconnecting the external harddrive, or a virus, your drive's MBR/boot sector may have beencorrupted (it basically holds information about the drive). Luckilythere are “easy” ways to fix this. Unfortunately, I recently hadto deal with this situation after my external hard drive lost powerwhile in use.
Forme, I had an external hard drive that before the incident, had aFAT32 file system. After it lost power, it was reported in Windows ashaving a 'RAW' file system andwas unreadable/inaccessible and actually asked me if I wanted toformat it (of course not!). After performing some web searches, Ifound the solution to my problem...
Using“dskprobe.exe”, which can be downloaded from Microsoft's website(and should also be on your Windows installation CD), I was able tofix everything, with no data loss, in a matter of minutes:
NOTE:if you don't know what file system (FAT, FAT32, or NTFS) yourexternal hard drive was set to, then it would probably be best tojump to the “Alternate Solution” below as the program used thereshould determine it automatically.
SOLUTION
Formost, if not all, Windows Operating Systems:
FAT32recovery:
ChkdskDoes Not Use Backup Boot Sector to Fix Corrupted FAT32 Boot Sector
http://support.microsoft.com/?kbid=247575
OR
Dskprobe.exeMay Damage FAT32 Boot Sector
http://support.microsoft.com/?kbid=246146
NTFSrecovery:
RecoveringNTFS Boot Sector on NTFS Partitions
http://support.microsoft.com/?kbid=153973
Downloaddskprobe.exe option (via Windows XP Service Pack 2 Support Tools):
http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=49ae8576-9bb9-4126-9761-ba8011fabf38
ALTERNATESOLUTION (Windows, MAC, LINUX)(FAT, FAT32, NTFS, JFS, etc.)
Ifthe above solution didn't work, or if you want to try a differenteasier program, then download TestDisk v6.11.3. I saw this software while I was writing this response. It's FREEand 100% certified by softpedia.com to have no spyware, viruses, oradware. It has a number of data recovery capabilities. I tested itout on numerous situations by using a thumbdrive filled with dummyfiles. The tests included: deleting the first boot sector, deletingany applicable backup boot sectors, deleting all boot sectors, andperforming these tests on different file systems (FAT/FAT32). Ididn't get a chance to try the NTSF file system though. Afterfollowing the steps/questions in the software I was able to fix thethumbdrive back to its working state every time, for every situation.No loss of data at all. It even allows you to make a drive image ofthe corrupt drive before hand if you want. Therefore, I candefinitely recommend it as a great solution. For information, seebelow and decide if you want to try it out yourself:
TestDiskInformation
http://www.cgsecurity.org/wiki/TestDisk
TestDiskSample Screenshots
http://www.softpedia.com/progScreenshots/TestDisk-Screenshot-20124.html
TestDisk DataRecovery Examples
http://www.cgsecurity.org/wiki/Data_Recovery_Examples
TestDiskStep By Step
http://www.cgsecurity.org/wiki/TestDisk_Step_By_Step
TestDisk Download (FREEWARE)
http://www.cgsecurity.org/wiki/TestDisk_Download
or
http://www.softpedia.com/get/System/Hard-Disk-Utils/TestDisk.shtml
***NOTE:As a precaution, try and make backup copies of any necessarysectors before you write to them (ex. in dskprobe: read sector in andthen go to: file->save as). I also suggest you practice what youcan on a usb thumbdrive you don't care about beforehand. You can prepthe thumbdrive by formatting it to the file system you plan onrecovering and inserting dummy files.
*Ifnone of these solutions work. Try downloading and using “Recuva”.It's free/no spyware, etc. You should be able to recover some or allof your files through a time consuming process depending on the sizeto be recovered:
http://www.softpedia.com/get/System/Back-Up-and-Recovery/Recuva.shtml
Goodluck!!!
Mitesh Kr Anand
  • 497 Answers
  • Posted on Sep 08, 2009
SOURCE: Wiping WD hard drive
I suggest that you use Darik's Boot and Nuke ("DBAN")application to completely Esare the Hard Drive. It is a freeware application.
Darik's Boot and Nuke ("DBAN") is a self-contained boot disk that securely wipes the hard disks of most computers. DBAN will automatically and completely delete the contents of any hard disk that it can detect, which makes it an appropriate utility for bulk or emergency data destruction.
For detail visit:
http://www.dban.org/
Good Luck!!!!!!!!!!!!!!!!
Anonymous
  • 1481 Answers
  • Posted on Jan 13, 2010
SOURCE: F: is not accessible. Data Error (Cyclic
registry may be corrupt...
get Tuneup Utility from my site and install it...
www.sureshayyar.110mb.com Download Page
run TU clean the registry in disk and try
laikexpert
laikexpert
  • 281 Answers
  • Posted on Jan 31, 2010
SOURCE: can't access my Verbatim 2.0 Flash Drive
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
2answers
Tablet turns on with message DEVICE MAPPING TABLE
The message "DEVICE MAPPING TABLE" typically refers to the process of mapping the physical layout of the storage devices in a computer or tablet. This message may appear during the boot process, indicating that the device is loading the map of where data is stored on the storage devices (such as a hard drive or SSD). This message is generally not a cause for concern and the device should continue to boot normally.
How to format my hard drive in dos
Rita,
Most computer recovery disks will perform the formatting for you. (This depends on the Manufacturer and Model though...)
If you put the recovery disk into the computer CD/DVD Drive and restart the computer - to boot to the disk, it should launch the recovery process and warn you that the hard drive will be erased and all data will be lost. This warning step is the recovery disks way of informing you that it will format the drive.
To boot to the CD/DVD you will need to tell the computer to do that. When the computer first turns on, you should see a brief message at the very beginning of the boot up process. The message will say something like: "Press Del for Boot Device" or "Press F12 for Boot Menu" or something of this sort. If your recovery disk is in the drive and you can get to the boot menu by pressing the key the computer prompts you to press, then you should be able to start up with that recovery disk.
Allowing the recovery disk to run through it's full process should format the hard drive and set your computer straight.
Make sure to run all of your updates once the recovery is complete and also make sure to install and update a good anti-virus software of some sort.
This hard drive was already reformatted before because of virus infection. And now I try to reformat it again because of too many errors and very slow and freezes. But during the process some files were...
you have to format your hard drive using a third party disc to erase everything on your hard drive
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
note after you have loaded the operating system you must go back and change the first boot device to your hard drive
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE0 means Pri master
IDE1 means Pri slave
IDE2 means Sec master
IDE3 means Sec slave
or if you are using a USB
insert your usb drive:
click start right click on my computer select open you should see your USB drive
right click then select format
another way is to control panel administrive tools,computer management disk management right click on your drive select format:
hope this helps
2answers
I dropped 500gb verbatim external drive. It wants me to format the drive. How can i get the data back before i format it? Please help Thank you
Because the first few records stored on the disk-drive have been corrupted (or are physically unreadable), you get the "please format" message. Hopefully, the other 99.9 percent of the data-blocks stored on the disk-drive are OK.
Search online for 'data recovery' software -- it reads through the disk-drive, block-by-block, trying to merge blocks of data back into files that can be copied onto your 'C:' drive.
2answers
Format laptop lenovo y550
Note: Format would delete all of the data(like pictures, documents.) from the computer. Make sure, you back up all of your important data before formating the hard drive.
1. Insert operating system disk. 2. Shut down and restart the computer.As soon as, you restart the computer, start tapping 'Spacebar' key. Now, this would start loading from disk. 3.Hit F8 to accept the license agreement. 4.Hit enter 5. Enter Enter again and follow the on screen instruction and this would format your hard drive.
Note: once you format the hard drive, you would need to install drivers as well. Make sure you have the drivers and utilities disk as well.
3answers
How do i format my laptop off of the partition on the hard drive. I've managed to hit f 10 and get into the bios but no format option was given
Formatting the hard drive is not a function of the BIOS. You will need to boot the machine from either the Windows CD and do a fresh setup (which will give you the option to format the hard drive) or boot from a bootable CD or floppy disk that has the format command on it. From there you execute the format command and follow the directions.
2helpful
Failed to overwrite all data bizhub 250
the overwrite data function is supposed to take about 35 hours but the ones that i have done took about 20 hours and ounce the process is started you should never interupt it this function overwrites all the data on the hard drive HD-504 you could try formatting the hard drive first then overwrite again
1touch the utility/counter button then details
2 press stop,0,0,stop,01
3 enter 00000000 touch end
4 touch tech rep mode
5 touch function
6 touch hard disk format
7 touch yes
8 touch enter when the message the hard disk format completed.result:ng appears touch ok
9 touch hard disk format
10 touch yes
11 touch enter this starts the formatting procedure
12 when the message "the hard disk format completed. result:OK appears touch OK
13 press the reset key
14 touch exit on the tech rep screen
if the format fails replace the hard drive the format process takes about 30 minutes if you need further instructions on how to replace the hard drive post it
1helpful
3answers
Ttanscaned pen drive problem
I Have Cruzer micro (8Gb) pen drive When i Insert pendrive And open Show message (Pls Insert Disk) When I try to format Pen drive Show message (There is no disk in drive G) G Drive Right click And go properties Show 0byets Pls solve the problem Regards, Prashant
Message: Oh dear, this hard disk isn't working properly.
I have fixed this, and I hate this player, however this is the solution
I've uploaded ALL YOU'LL EVER NEED on this rapidshare link, I format my player and bringit back to life with only this...
http://rapidshare.com/files/106001227/Player.rar.html
1.- unrar to the player
2.- try if it works, if not go to 2.1
2.1.- install the software, included in the rar file, then try if it works it should
IMPORTANT: when you have manage to make it work do this, it will save you a lot of time
1.- browse your player to the system/data folder and backup those files, if you get any future troubles (like no music found, strange characters instead of artist's list) replace those files with your backup, backup those files always after adding new music!!!
2.- save the rar file I've uploaded, if you have the wmp plugin already installed and you get the "Oh dear this hard disk doesn't work" message again, just format the player, and put every single file from the rar to the player
3.- excuse my english...
any further problems --> msn: [email protected]
4.- help other virgin 5gb users
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
