Cell Phones Logo
Krystal Burnett Posted on Feb 02, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My phone will no charge while it is on the charger
I have a straight talk ZTE savvy phone and today when I went to charge it, it would not charge while on the charger. it stayed at 25% charged for 3 hours and hasn't changed since. I have checked my charger cord and the outlet it was plugged into. I don't see any damage to my charge port either.
Jim Dowell
Level 3:
Master:
  • Master 345 Answers
  • Posted on Feb 02, 2014
Jim Dowell
Master
Level 3:
Master:
Answers
345
Questions
0
Helped
121304
Points
1057
Sometimes the block transformers on phone chargers go bad. I'm assuming it uses a micro usb plug like most phones do now. The easiest way to check is to borrow a charger from someone else or if you have a kindle charger use it to see if the phone will charge. If it does don't go back to the phone store to get another one because they charge an arm and a leg. You can order the chargers for most phones online for half of what you pay at a phone store.
5 Related Answers
Anonymous
  • Posted on Jan 29, 2009
SOURCE: Virgin Mobile Wildcard Phone Won't Charge!!!
okay, this happened to me too.
first you need to call virgin mobile and ask a live advisor for help.
if they ask you to take the battery out and press the power button for 30 seconds and it doesnt work then they will try to send you a new charger.
when i called it was out of stock.
you can also but the car charger.
hope i helped :]
Anonymous
  • 482 Answers
  • Posted on Apr 17, 2009
SOURCE: BATTERY UNABLE TO CHARGE
shorting out battery
Anonymous
  • 1952 Answers
  • Posted on May 30, 2009
SOURCE: Charging problem
try to change the battery.........
Anonymous
  • 625 Answers
  • Posted on Jul 05, 2009
SOURCE: BATTERY UNABLE TO CHARGE, ALTHOUGH PHONE WORKS
Well, the white to pink dot is a sign of water in the phone. It is a moisture indicator and the first thing the repair fols look for so they can deny any claims.
They second thing is you can get an external battery charger for the razor. They run about 5 dollars and allow you to charge the battery seperate from the phone.
Razr V3 external battery charger
Anonymous
  • 30 Answers
  • Posted on Jan 07, 2010
SOURCE: Charging problem with Sony Ericsson w880i
5% of the mobile phone experience this problem you have to check it out with the mobile store
While charging my ZTE Merit phone, the phone went dead. Does not respond to any pressing of any buttons. Only thing on is red return light bottom right of screen. What is wrong?
go on amazon and buy a New battery for $5.00+ and it will work for you, same thing happened to me. New battery solved the issue... well worth the 5.00$
How come my straight talk zte cell phone wont turn on?
Two possibilities
  • The battery is not charged and/or completely connected
  • The phone is dead
Try turning it on with the battery in AND with the phone plugged in to the wall charger. If it continues to do the same thing, return or exchange it.
2answers
How to hard reset a ZTE Savvy
Hi Joshua,
I have this video for you on how to reset your device. Hope it helps.
May 03, 2014 • ZTE Score
ZTE Savvy Z750C stuck on startup ZTE logo
Go as though you are going to perform a master reset as per the tutorial here http://www.satechhelp.co.za/39/rest-zte-savvy-straight-talk?show=39#q39 but select "Wipe cache partition" instead, reboot using the "Reboot now" option and see if it doe not get passed the logo screen. You will have to perform a master reset as per the same tutorial on the link above if the issue still persist.
1helpful
I have a straight talk phone, android ZTE will not charge? ?
I am sorry to hear that your unable to charging your phone, did you try with different battery or charger, if you have tried and the phone still not charging than in this case you need to contact straight talk they will be able to fix the phone for you. The contact hot-line of straight talk is number 877-430-2355.
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
