Customer care support SERVICE number+1-
-833'''272''''0777,,,,,,,,,,,call them
Need go to menu screen display and reduce bass to 1/4 level. Do not set more then 40%
This is typical of sound systems that come with TVs, especially flat screens. You need to look into purchasing an external sound system, such as a sound bar or a surround sound system. That way you can have better control of background/voice ratios.
No. The reason they give Academy Awards to SoundMixing, is because some do it great, and some do it bad. Once the dvd is printed, there is nothing you can do about the mix of the sound between background and voices. it's just a bad mix. oh well, the same thing happened to me about a week ago, but as the movie went on, the sound mix either got better, or my ears started to tune into the voices better.
You can't. Audiobooks are just like music, and the Sansa treats them that way. Think of them as words spoken without music.
Voice recordings are made on the Sansa, when you use it as a digital recorder. You can record lectures, meetings, or notes to yourself, and play them back.
There are a total of eight folders in the recorder that are in a tree format. Under the “Root” folder are “Folder A” through “Folder E”, “Audible” and “Music” folders, and recorded or transferred Language and music data from a computer can be saved as “files”. “Folder A” through “Folder E” are voice-recording folders, so choose one of these five folders when recording on this recorder. Up to 200 files can be saved in each folder, and up to two layers can be created within the “Music” folders.
I also had this problem. I read elsewhere that this happens when your TV's audio setting are set to surround sound when you don't actually have a 5-speaker system. I changed the settings to regular stereo and it fixed the problem perfectly.
erm,, when you say you cant hear voices clearly. do you mean that they seem to be a little lower in "obviousness" than they should be or are they way down ther as the background level is so much higher.
1. a little lower means you need to bring the trebble up and the bass down and bring up the centre and reduce the surround , this is basically tuning the sytem to your room.
you also need to check the dvd setting for audio out to ensure that the settings for the audio on the dvd are set to 5.1 ( if the little black spare connector is connected to your dvd player) or else set to stereo for "normal " palyback.
2. if the voice is way down compared to background sound track.
are you using an amp for the bass channel, this may need to be turned down. or the thing that looks like a spare connector on the end of the cable going to your cd5 unit is not correctly installed. can you tell me what the set up is.
With your mp3player attached, open my computer look for "MyMusix pd.."-something like that and then open "Music".
Now that you have that window open,
open the folder where you have your music in [My Music]
Now simply drag the songs to the music file on your mp3 player.
Coby dvd plays background music and all previews( music and voices ) but the actual movie we cannot hear voices only back voices and music can be heard.
