Had it unplugged, as it wouldn't start after selecting the micro setting? Code F3 now shows?
SOURCE: Micro beeps 3 times with "F3" flashing on LCD screen. Nothing works.
If it's a GE model, F3 will mean a shorted key panel.
(If it's not a GE, please reply back with your brand and model number so we can help you).
If you might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
BUT If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
SOURCE: my ge spacemaker XLl800 starts beeping and then
possible magnetron failure, check for short in high voltage and remove mag and inspect
SOURCE: ge microwave jvm 1430 error code F3
F3 Key panel (touch pad) shorted This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
An F3 code means that the touch pad has a short. The touch pad needs to be replaced. If you purchased the microwave new, get your receipt and the unit serial number and contact GE for the repair (1-800-GE-CARES). See http://repair.geappliances.com/ to find a repair center near you. There is a one-year parts and labor warranty on this part. You will need to get the unit to the GE Repair center at your own expense. (I'm assuming that the unit wasn't shorted by a lightning strike or other disaster.)
I hope this helps.
Error Code/Message - Oven - F3 Error Code - F3 E0
Control displaying F3 E0:
There may be a problem with the Oven Temperature Sensor, or the associated wiring.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation.
