Bench Factory-Reconditioned Ryobi 2.1 Amp, 6"  Grinder ZRBGH616 Logo
Posted on Jun 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can I get a Ryobi hand grinder FA3-4 On/Off switch
  • Anonymous May 11, 2010
    What is the model number of the angle grinder (FA3-4 does not come up as a model number)
  • john graybeal
    john graybeal Sep 26, 2019
    That's the number for the switch
Anonymous
Level 2:
  • Expert 106 Answers
  • Posted on Jun 05, 2009
Anonymous
Expert
Level 2:
Answers
106
Questions
Helped
48641
Points
386
1 Related Answer
Anonymous
  • 225 Answers
  • Posted on Jun 14, 2009
SOURCE: where can I get a FA3-4 Ryobi grinder on/off
try radio shack,or electronics store in your area
1helpful
Where can I purchase a EPJ800/72 240 volt switch for a ryobi 100mm angle grinder in the post code 4507 or south east Queensland
bunnings have exclusive rights to ryobi
take the details to their special orders counter and have them order one in If it is available
if not available you may get one from e-bay overseas
a switch is a switch and the voltage is not a problem as you have a part number ,
you may get one from tool parts shop so go google and type in ryobi spares and there are sites in Brisbane that have parts for a range of tools including ryobi, if not in other states
Dec 22, 2016 • Ryobi Saws
Wher can i get a output shaft for a ryobi EAG95100angle grinder 900w
go google and type in--- parts for ryobi 4 " angle grinder model eag 95
I recently spent may hours searching for parts for ryobi angle grinder 4" that is close to 45 years old and saw plenty of sites for ryobi and others that carried listings for many ryobi grinders
I suspect that you will be lucky as you have a model where as I didn't have that luxury
Jul 08, 2016 • Ryobi Saws
How to change a grinder blade on a ryobi grinder
Handheld grinder or bench grinder? I'll assume you're asking about a handheld grinder.
Engage the arbor lock. You may need to rotate the wheel until you find the spot where the arbor lock locks the wheel. Use a wrench or a gloved hand to unscrew the wheel (I use my bare hand). Screw the replacement wheel on and disengage the arbor lock. The new wheel doesn't need to be very tight, it'll tighten itself as you work.
Jul 15, 2014 • Saws
How to repair angle grinder trigger switch
The switches I have seen can not be repaired but replaced.
Apr 28, 2014 • Ryobi Saws
7helpful
2answers
Replacement carbon brushes Ryobi AG402 angle grinder
You can purchase replacement carbon brushes on amazon Amazon com Ryobi carbon brushes. I hope this was helpful. cheers
Jul 12, 2013 • Saws
18 v Driver. Need trigger switch
Google ryobi stores. I'm in az and they have them here. Or ryobi repair and your location. I went to the dewalt replacement shop got a trigger for my angle grinder for under 2 dollars.
I have a Ryobi 4'' Grinder Model G-1000/1150
The Grinders are made by TTI they will be able to get you replacement brushes. But to be perfectly honest its not worth repairing a 4" Ryobi they have a rather short lifespan and are not balanced very well. The cost of brushes and shipping may be very close to that of a new grinder, espicially if you need a new armature.
TTI can be found here:
http://www.ttigroup.com/en/our_brands/by_division/power_tools_and_accessories
Cheers,
Jan 06, 2010 • Saws
Ryobi Bench Grinder with Linisher tracking difficulty.
It sounds like the pulley is not adjusted correctly. This is causing the belt to move on you. Carefully inspect and adjust the pulley so it is square and flat. Use a straight edge.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jun 25, 2009 • Grinders
Top Bench Grinders Experts
Oliver Street
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Bench Grinder Expert? Answer questions, earn points and help others
