Question about D-Link Computers & Internet
Whenever I connect my E63 mobile with the D-Link router, the D-link router starts rebooting. And it happens again and again. Also the problem is not with the router as it does't reboot when other mobiles are connected to it. It starts rebooting when e63 connects to it.
6ya staff
SOURCE:
Anonymous
SOURCE: My D-link keeps loosing connetion to wireless network
I am having the same issue. My adapter also loses connectivity randomly. I right click (I use Windows XP) the little icon in the bottom right corner and select repair connection. It will repair the connection most of the time but it usually loses the connection soon after...
Posted on Aug 10, 2008
Anonymous
  • 16 Answers
SOURCE: Router Connectivity
It will be one of two things or both - either your computer is not setup for DHCP or your router is using the same IP address as your ISP or both.
To check ISP IP address connect your computer to your modem then: from start => run => CMD (hit enter after this)
a command window opens, type "ipconfig /all" without the quotes.
The line with "IP address" gives you your ISP IP addr.
Compare this with what you get from your router manual if they are the same then do the following:
To configure your computer to use a DHCP IP address, go to the Control panel => network connections => Properties (right click on your default connection) => double click Internet protocol (From general tab) => (a new window pops up) from the general tab ensure that "obtain an IP address automatically" is selected.
To change the IP address of your router check your manual and do the following:
IP Addr => 10.10.1.1
Sub net mask => 255.255.0.0
Default gateway => IP address from your ISP
Make sure to the router is set to act as a DHCP server.
You should be up and running.
kakee
Michael Galve
  • 1269 Answers
SOURCE: D-link Router DIR-625 resets itself
You need to open the router's setup page (admin page) http://192.168.0.1 to enable the wireless security
Posted on Feb 13, 2009
Jess
  • 742 Answers
SOURCE: Access internet on pc though Nokia E 63 Mobile phone.
yes. just connect your phone to your PC and open network connections... from there, you can choose to open internet using the network provider by your phone's GPRS
Posted on Sep 24, 2009
ranjit kumar
  • 438 Answers
SOURCE: connection
it says u that internet connection is not der in ur mobile..call ur customer care for this...they ll activate the internet!!!!!
Posted on Sep 29, 2009
TP-Link TL-WR841N Wireless-N300 Router dropping connection
Do you experience problems with other WiFi hotspots?
Dec 12, 2013 | TP-LINK TL-WR642G Router
D-LINK DI-524 coverage Issue
You can reboot ALL the devices . Unplug the Modem, remove battery, Unplug the D Link. Install battery in Modem, plug into AC, allow the device to selftest, plug in D Link allow it to self test. Reboot computer. Have you secured the wireless? Changed Channels for better signal? Take a look at this: http://www.microsoft.com/athome/setup/wirelesstips.aspx#fbid=nZTFiYrDLMg
Dec 05, 2012 | Computers & Internet
My router will not connect to my mobile so i can use WiFi
What is your mobile brand/model?
Click on the links below to know how to connect an Android tablet or smartphone to the wireless network.
LINK
Oct 29, 2012 | Belkin N300 Wireless N Router
Wireless connection keeps dropping
Ok, START>>RUN>>services.msc (enter) When the windows comes up, scroll down to DHCP, set to OFF & Disable. Then find, Zero Configuration, and do the same, back out, and reboot. See if this helps any.
Apr 03, 2010 | D-Link AirPlus DI-524 Wireless Router
My Nokia E63 Mobile is rebooting without warning
change your memory
or scan your mobile may be you have a virus
Apr 03, 2009 | Nokia E63 Cell Phone
DI 524 Frequent Wireless Network Loss
Try changing the channel of your router ex (channel 1-6-11). Since you upgrade the firmware of your router you need to reset it to factory default and reconfigure everything so the new firmware will take effect.
May 09, 2008 | D-Link AirPlus DI-524 Wireless Router
D-Link DI-614+
If your ISP is not having problems typically a router will just need a reboot to make it start working again. Simply unplug the power cord to it, wait 10-15 seconds, plug back in and try it again.
Jun 16, 2007 | D-Link AirPlus DI-614+ Wireless Router
Open Questions:
Computers & Internet Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
