Canon imageRUNNER 2000 Copier Logo
s
siva266ster Posted on Feb 01, 2014
Processing light is on papar not pickup - Canon imageRUNNER 2000 Copier
jahanrahim
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 46 Answers
  • Posted on Feb 17, 2014
jahanrahim
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
46
Questions
Helped
17943
Points
58
If there is no message on display...and if machine running for a long...pls check the toner, some times its not showing on the display
I dont know how to wire lights to trailer from 1986 toyota pickup
You need a "test light". Then you turn on the circuit you want to wire in, tail lights, brake lights, blinkers and poke around the back of your light sockets until the test light comes on. Then you splicew into that wire and run it to your plug in. If you don't know which wire is what on the trailer, hook it up and with the wire fastened into the truck harness, try it on the trailer harness wires until you get the proper lights working. Process of elimination. Hope this helps.
How do you use a NEXXTECH Laser Lens Cleaner?
The NexxTech Laser Lens Cleaner uses six super-soft brushes to ensure thorough and reliable cleaning, without harming the delicate optical components of your disks. Enjoy your DVDs more and improve your music archive by cleaning your optics in your CD or DVD ROM. The easy-to-use audio instructions walk you through the cleaning process from start to finish. This laser lens cleaner process will prolong the life of your disc player, improve visual clarity and sound quality. Features
  • Works on CD, DVD, Blu-ray - all optical drives
  • The six brush system cleans off the entire laser lens
  • Will not damage sensitive optical components
  • Includes easy-to-use audio instructions
How to Clean the Laser Pickup Lens on your DVD Player X missing_author_image.png eHow Electronics Editor This article was created by a professional writer and edited by experienced copy editors, both qualified members of the Demand Media Studios community. All articles go through an editorial process that includes subject matter guidelines, plagiarism review, fact-checking, and other steps in an effort to provide reliable information. By an eHow Contributor
Is your DVD player malfunctioning? If you're getting a no-disc error, you may need to clean the DVD player's laser pickup. The laser pickup is what reads DVD's and allows you to view them on your TV. If you need to clean the laser pickup lens on a DVD player, follow these simple steps.
Difficulty: Moderate Instructions things you'll need:
  • Isopropyl alcohol
  • DVD lens cleaner
    • 1 Make sure the laser pickup lens is actually the problem. There are a wide variety of reasons that a DVD player might not read a disc efficiently. The disc could be scratched or dirty, for example. Test the DVD player with a disc that you know works before trying to clean the lens.
    • 2 Purchase or borrow a lens cleaner disc and try it first. You can find these things really cheap at any large department store. They usually get the job done well. However, you may need to clean the lens manually if the store-bought cleaner fails.
    • 3 Remove the outer casing of the DVD player. Remove the screws that mount the top casing onto the bottom of the DVD player and slide the top casing off. This will expose the DVD deck, which houses the laser pickup lens.
    • 4 Find the lens. The lens will be glass and under the DVD clamp. The lens will probably have a blue tint to it. If you are having trouble finding the lens, you could shine a light on the components and watch for the reflection.
    • 5 Use a cotton swab and some isopropyl alcohol to gently wipe the lens. Just a quick scrub will do. Dry the laser pickup lens with the other end of the swab.
    • 6 Give the lens a few seconds to dry and replace the covering of the DVD player. Test the efficiency of the player. If necessary, repeat the process.
1992 Pickup: how to change a starter on 92 toyota pickup...
disconnect the battery take the power wires off the starter turn the bolts counterclockwise pull up slightly on the starter and pull out reverse process to reinstall.
Papar jam
Hello sir; Wherever you clean up the paper jam, right over there have a paper senser ,check that senser is moving freely or out of track, just put it back to right possition.
2helpful
Acer Aspire t160 issues
ok heres how you remove bios password.
Open the door where the RAM is fitted and remove RAM from the holders. Look for two metal bars (GOLD?) near or between the RAM sockets.
Take a papare clip and short the bars out against each other. Replace the ram close the trap and reboot. That should do it
Please rate the help to keep the FREE service online ++++ Thanks for uisng Fixya
It does not pick papers
There's really nothing in common except the motor. When you have the covers off, the printer will default to the manual tray because the sensor arm is on the cover. If you want to check printing from the lower tray with the cover off, you have to block the MF sensor. A folded piece of paper works well. You made no mention of lights coming on and at what point. Need that info to diagnose it any further.
2000 Nissan Frontier replace headlight
there is a holder for the head lights you have to unscrew this holder from the outside on the front of the truck unhook the plug on rear of head light then reverse the process to reinstal good luck
2answers
Paper Jam
Sak passe!! you did not specify where the jam is?
14helpful
10answers
Lost Installation CD for my Brother HL-2040 printer
Where Can I download installation software for Brother HL-2040 printer
old marine
old marine
ZJ Limited
ZJ Limited
