I can't figure out how to change my phone back to tone dialing. It changed to pulse on its own.
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
For model KX-TGA101S ( KX-TG1033S) Panasonic cordless phones: Just follow these simple steps:
1. press menu button standby (off mode)
2. press round arrow control DOWN repeatedly until "Set tel line" appears.
3. press "OK" to select "set tel line.
4. press "OK" to select "set dial mode"
5. when "set dial mode"appears select your desired mode (tone or pulse).
6. after making your selection, be sure to press and hold the menu (OK) button to register it.
L. Meltzer, P.E.
L. Meltzer, P.E.
SOURCE: phone went from touch tone to pulse. . .
Read the manual to reconfigure that option. (Look for Setup button on the phone) I can't guess what model you have. On older phones one could find a switch on the the phone to flip between Tone and Pulse.
Sorry I could not be of much help.
