Dishwasher does not work. reset and normal lights flash and will not go off
SOURCE: Whirlpool Gold flashing 'NORMAL' light, will not reset or work
Could be either the keypad is faulty or the control board is bad.
SOURCE: Whirpool Dishwasher ADP5966 Turned dishwasher on.
Most likely the door switch is not making proper contact when you shut the door or the Start button is faulty. Needs someone to look in the door panel to fix.
SOURCE: Quiet Partner II Whirlpool Dishwasher 2 years old,
Unusual LED or Display Readouts Open ID diodes and/or LED circuit(s) in keypad, or open circuits on the control that drive
See "Checking Keypad Operation."
Press the following in sequence...Then try touch pad......
HEATED DRY ? NORMAL ? HEATED DRY ? NORMAL ? HEATED DRY ? ORMAL
here is the deal...if the touch pad is unresponsive after entering the above in sequence then you will need to change out the touch pad.
here is the link to your model....part number 1 on the drawing...there are three different ones....the difference is the color.Click on the link http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Dishwasher-Parts/Model-DU1100XTPBA/1198/0130000/W0702219/00002?blt=06&prst=&shdMod=
Here is a link that will show you the three differnet colors...I would order from these guys....1 year warranty on parts no questions asked
click on the link http://www.repairclinic.com/Touchpad-Parts?s=t-DU1100XTP-%3d%3dc63
could be a fuse in control panel or a bad circuit board
