Check the status of the printer at Control Panel. Set it to online if it's shown as offline. If this doesn't fix the problem, check whether installing the vista driver available at your printer manufacturer's website helps.
Step 1: a. Click Start, go to Control Panel and select Hardware and Sound. b. Click Printer. c. If the Printer is offline, it shows "Offline" status. If the Printer is online it shows "Ready". d. If the Printer is offline, set it to online. e. Right-click on the printer and select "Use Printer Online". f. The display should change to ready when the printer is set to online.
Step 2: If still you are facing issues, then update the printer driver. This should fix the problem.
For further precise instructions, please let me know the Operating Systems installed on the Computer.
Once you have added either a USB or networked printer to your PC or Mac computer, you can begin sending documents to print. However, on occasion, a print command will create an error on the printer and take it offline, which will prevent all future jobs from printing. To resolve this issue, you will need to change your printer settings from offline to online. PC Instructions - Open the Start menu and click on the "Printers and Faxes" icon. This will open a window with a list of the printers currently set up on your computer.- Double-click on the icon of the printer you want to change to online. A pop-up window detailing all current print jobs will open.- Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online.Mac Instructions - Open System Preferences by clicking on the icon in the Dock.- Go to the Print & Fax control panel under the Hardware category.- Select the printer you want to take online from the list on the left side of the screen. Then click on the "Open Print Queue" button.- Click on the "Resume Printer" button at the top of the queue window to change the printer from offline to online.
hi
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
·Step 1 Open the Start menu and click on the
printers currently set up on your computer. ·Step 2 Double-click on the icon of the
print jobs will open. ·Step 3 Go to Printer in the menu bar of
change the printer from offline to online. Mac
Instructions·Step 1 Open System Preferences by
clicking on the icon in the Dock. ·Step 2 Go to the Print & Fax
control panel under the Hardware category. ·Step 3 Select the printer you want to
"Open Print Queue" button. ·Step 4 Click on the "Resume
offline to online.
Step 1 Open the Start menu and click on the "Printers and Faxes" icon. This will open a window with a list of the printers currently set up on your computer. ·Step 2 Double-click on the icon of the printer you want to change to online. A pop-up window detailing all current print jobs will open. ·Step 3 Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online. Mac Instructions·Step 1 Open System Preferences by clicking on the icon in the Dock. ·Step 2 Go to the Print & Fax control panel under the Hardware category. ·Step 3 Select the printer you want to take online from the list on the left side of the screen. Then click on the "Open Print Queue" button. ·Step 4 Click on the "Resume Printer" button at the top of the queue window to change the printer from offline to online.
the message "phone off hook" is a normal message if you will used your phone, just ignore that message.
- if you cant print first thing you do is to goto start>control panel>printer and faxes then check the iocn if it is online of offline if it is offline just right click the icon and set printer online and if there is pending documents, right click again the icon and select cancel documents.
- if still the same your printing is not printing then you must uninstall and reinstall the software
perform the steps below if the Operating System is XP
Step 1: ===== Determine if the printer is paused or offline : =============================
1.Open the printers folder, if necessary. a.Click the Start icon. b.Click Control Panel. c.Click Hardware & Sounds. NOTE: This step is not required when using Classic view in Windows Vista. d.Click Printers.
2.Right-click the name of the printer and then click Open.
3.Click Printer.
4.Verify that Pause Printing and Use Printer Offline are not selected.
5.Press Esc to close the window without making any changes.
Step 2: ===== Check for the default printer and USe printer Online in the printers and faxes folder. =========================================================
Click Start -->> Control panel -->> Hardware and sound-->> Printers-->>Change default printer. ---> Please Right Click on the printer icon which has tick mark and Select the options Use printer Online and Set as Default and also Select the option Resume printing.
