Cobra 29 LTD CB Radio Logo
Joseph Midjette Sr Posted on Feb 01, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can I find a new replacement modulation transformer for a cobra 29 ltd classic?
I have dead key, Rx works, TR17 tests good, New Tx final fixed no dead key, still have no modulation, mic tests good, used buzit on pin 4 of audio chip and get noise through speaker until I key the mic. Think I need a modulation transformer. Unless someone knows something else I'm missing to check. Also, how do I test the modulation transformer to be sure it is the culprit?
Paul Adkins
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 1 Answer
  • Posted on Jan 21, 2020
Paul Adkins
Contributor
Level 1:
Welcome Back:
Answers
Questions
0
Helped
556
Points
Cheap CB Radio Equipment, Check It Out https://cbradioequipment.com
Mike Charette
Level 3:
Genius:
  • Cobra Master 1,847 Answers
  • Posted on Mar 09, 2016
Mike Charette
Cobra Master
Level 3:
Genius:
Answers
1847
Questions
Helped
489690
Points
2211
If you are thinking about replacing the transformer you can either get one through Cobra or remove one from another radio.
Tribe Ningo
Level 2:
New Friend:
  • Expert 84 Answers
  • Posted on Feb 01, 2014
Tribe Ningo
Expert
Level 2:
New Friend:
Answers
84
Questions
Helped
13712
Points
126
Simple,just chech the input resistance and out put...they should have even small resistance always example .5ohms .3 ohms it counts...
  • Joseph Midjette Sr Feb 01, 2014
    input and output resistance on what?
4 Related Answers
Tumbleweed01
  • Posted on Mar 16, 2008
SOURCE: 29 help
hi, sounds like you have a problem with the SWR' S Probably too high. Tumbleweed01
Anonymous
  • 200 Answers
  • Posted on Jan 22, 2009
SOURCE: cobra 29 nw ltd won't transmit
Have you cracked the radio open yet?  check for loose connections etc.  get back to me if that doesnt yeild any results
Ernest Taylor
  • 67 Answers
  • Posted on Feb 27, 2011
SOURCE: cobra 29, no rx, no tx, pa dose not work, good
Not sure which model you have as there are at least 13 cobra 29's. I am using the LTD as an example. You say good mic? Is it made for this model? If it is good then I would have to say the final audio stage is not working. The TA72222AP is the IC that is the final audio amplifier. Check pin 1 of the TA72222AP ic for 12 volts. If 12 volts is present then replace the audio IC TA72222AP. If 12 volts is not present then you have power supply problems that are internal. The conclusion I have made is based on no rx audio, ( could have been the jack at the pa and ext spkr) but you say they don't work either, also no meter movement during modulation check (that does not need a spkr to make the meter move) so yes I'm 99.99% sure its the final audio stage is a bad. If your model is not the LTD then the IC could be different but still the same audio final is bad. Replace the part which should be fairly inexpensive. If it uses a metal heat sink be sure to apply heat sink grease when installing new part.
Laron71
Laron
  • 146 Answers
  • Posted on Jul 02, 2011
SOURCE: Cobra 29 ltd Classic no
Check speaker and plug external one in if you have it.
swap mic could be a broke wire or bad switch in handset.
check antenna and coax connections.
i know checks sound basic but they could save you a lot of headaches later
2answers
Cobra 29 ltd Classic no sound, no rx, all lights work rx,tx, lite up. The SWR meter moves when mic is keyed up.
Cobra 29, no rx, no tx, pa dose not work, good mic, good ext. speaker, mic. gain all the way up, and you can see meter in face neddle moveing it rec. just no audio at alland no modulation.
Cobra 29 has good dead key but no mod.and no rx
probable took out the keying transistor. If you want it fixed give me a shout. Dodgem250.com
1helpful
Red RX/TX and red ANT light on my CB
Well,first hand ,some cobra radio,s have red some have green RX/TX lights, but are you modulating? Some green lights turn red. What is your standing Wave on the antenna,s? You need to check it and the output of the radio. To do this you need a watt or field strenth meter. Can get one at Radio Shack. Your standing Wave is ok as long as it is below a 2. That has to be done on the antenna. ..hope this helps...
MY COBRA 29 LTD CLASSIC WILL NOT TX BUT RX VERY WELL. CAN'T SEEM TO CALIBRATE CORRECTLY.
Hi and welcome to FixYa,
Initially, check the final and driver, TR14 and TR15 using a transistor tester or ohmmeter..
Postback results.
Good luck and thank you for asking FixYa.
Cobra 29 nw ltd won't transmit
No receive cobra 29 ltd classic
Initially, pls confirm that there is modulation (transmit audio). The reason I asked is if IC4 (TA7222P) is blown, then the radio would have no audio amplifier which would explain no receive audio. Additionally, the final and pre-final (TR15 & 15) gets is modulated TX+12 through D8 from T1 which in turn is the output of IC4 through C48.
Perhaps a schematic diagram may be of further help.
Good luck and Thank you for using FixYa. Happy Holidays.
17helpful
2answers
Cobra 29 Ltd Classic
In most cases just turning up VR4 is more then enough. Replacing the final, tr14 with another transistor requires changing many more parts to get it to work.
With a new 29, there is no need to change the final. Just turn vr4 all the way up and you will see around 20 - 25 watts. L13 won't gain you a single watt. L12 will raise the dead key, and usually you want a lower dead key for good swing. L14 will gain you a few watts, but don't adjust this unless you have a watt meter. You turn it out to increase wattage, but too much will over bias the final and shorten its life.
You hook it to a watt meter with a dummy load. Then say a steady AHHHH into the mic while keyed. Turn the slug out until the needle stops going up, then back it down to where it stopped.
The easy thing to do, and you will be pleased is just to turn VR4 up. Now, Up is counter clockwise. Its a variable resistor, so the less resistance, the more modulation. So you want to turn the VR down.
that will be more then enough.
2answers
Codra 29 nw ltd classic
For the money,the Cobra 29 nw/st is just as good if not better than a Galaxy. Cobra is more durable by far. I have had 3 of these cobra's in the last 30 years. Only had to replace the last one because the tractor got hit by lightning.
Sure would not pay big money for a name.
1helpful
29 help
Top Cobra Radio Communications Experts
Mike Cairns
Mike Cairns
eradiostore
eradiostore
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
